sticky tachometer, sticks at 2000 rpm's |
ice cold |
Sep 27 2014, 08:35 PM
Member Group: Members Posts: 90 Joined: 12-February 14 From: West Palm Beach Florida Member No.: 16,993 Region Association: South East States |
The tach on my 76 2.0 liter likes to stop at 2000 rpms when the rpms drop. Blip the throttle and it settles back to the proper rpms. Any ideas about a remedy? Is this a guage problem or a wiring issue?
bperry |
Sep 27 2014, 11:36 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
I had a similar issue about 30 years ago in mine.
In my case it was a warped lens on the gauge. The original lens in mine was plastic and it was warped concave and the needle would rub and hit the lens at about 2500 rpm and get stuck occasionally. I ended up replacing the plastic lens for a glass one I made at a art glass framing shop. I had to score the circle on the glass and break the glass myself because the guys at the shop were horrible at math. It was sad to watch them screw up the size twice before I finally just got them to let me use their tools to do it. It was simple you just had to do some simple math to calculate the radius (like divide the measured diameter by 2). They kept trying to eye ball it. The biggest part of the job was removing the ring on the front of the tach to get the lens out. It requires bending the back side of the retaining ring all the way around. The way you can tell if the lens is warped/bowed is to look at the reflection and check for distortions. In my case when I looked at it I could see myself magnified. I still think that is is really odd that the original tach lens was plastic. The glass I replaced it with was much clearer and still clear to this day whereas the original lens was a bit foggy after just 10 years back in 1984. --- bill |
bdstone914 |
Sep 28 2014, 09:14 AM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If it is a warped lend you can get a glass one from a 70-73 tach with the silver center.
Bruce |
Lo-Fi Version | Time is now: 10th May 2024 - 10:36 PM |
