Wiper Switch Conversion, Different for Early Cars? What am I missing? |
BeatNavy |
Sep 28 2014, 01:45 PM
So today was going to be a good day to do the wiper switch upgrade as my car's up on jackstands for brake issues and probably will be there for a few days. I was following the Pelican Article which describes itself pertaining to '74 (I've got a '72). But I've read through a lot articles on this, and I don't recall seeing any distinction between early/late cars. I ordered this 924 switch (part number 111953519G as per the article).
Anyway, once I started the process I ran into several issues which have me stumped. First of all, the quality overall seems sketchy. I had seen the caveats on the quality of this one, but even then the quality seemed suspect to the point that I'm not sure it would work at all. Then I ran into the following additional issues as annotated in the picture below: 1. The layout is different than what I had seen in other pictures, and the wire colors did not match the old switch. There's a contact anchored to the outside of the switch that I have seen in other pictures on the inside....which wouldn't bother me except... 2. ...it's held in place by a bolt and nut going through one of the holes that should hold one of the four metal sleeves that hold the turn signal and wiper assemblies together. WTF? I assume that this contact is necessary, but it will fall out without that bolt in place. 3. The actual holes in the metal piece through which the sleeves should slide were too small. I took a drill bit and by hand worked them wide enough so I could get the sleeves in, but it still makes me question if I have the right part. 4. Dog, recovering from ACL surgery, is no help at all. Has anyone else been successful doing this on an early car with this specific part (from this vendor) and do you recommend a different part/vendor? Thanks for your help. Winter's coming. I'd like to be able to clean the windshield. |
jt914-6 |
Sep 29 2014, 06:18 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Not off topic but I will add this. I have a delayed wiper switch that works on the 914. The only thing is that it has to be dash mounted. Early 914's, 70-71 or 72 had dash mounted wiper switch, but works on all year models. It is designed to work with the Bosch system. I have sold several with no problems and have installed it on two of my personal 914's and know, if wired correctly, it works. It's a knob type switch. The range of delay is from 4 to 17 seconds and when you push the knob it has a power outlet for a 12 volt pump for the washer feature. Anco makes a universal pump, or any 12 volt pump can be used. It also has a low/high speed too. You must tap into the 914's washer wiring to use it. Either wire it the connector or cut wires and wire it direct. Complete wiring instructions included. The price is $75 plus shipping. I know I have two or three left in stock. PM me if interested...... The pic is of the one in my '75. It is in the lighter spot, but there is a place to mount it on either side of the lighter.
Lo-Fi Version | Time is now: 13th May 2024 - 11:19 PM |
