Wiper Switch Conversion, Different for Early Cars? What am I missing? |
BeatNavy |
Sep 28 2014, 01:45 PM
So today was going to be a good day to do the wiper switch upgrade as my car's up on jackstands for brake issues and probably will be there for a few days. I was following the Pelican Article which describes itself pertaining to '74 (I've got a '72). But I've read through a lot articles on this, and I don't recall seeing any distinction between early/late cars. I ordered this 924 switch (part number 111953519G as per the article).
Anyway, once I started the process I ran into several issues which have me stumped. First of all, the quality overall seems sketchy. I had seen the caveats on the quality of this one, but even then the quality seemed suspect to the point that I'm not sure it would work at all. Then I ran into the following additional issues as annotated in the picture below: 1. The layout is different than what I had seen in other pictures, and the wire colors did not match the old switch. There's a contact anchored to the outside of the switch that I have seen in other pictures on the inside....which wouldn't bother me except... 2. ...it's held in place by a bolt and nut going through one of the holes that should hold one of the four metal sleeves that hold the turn signal and wiper assemblies together. WTF? I assume that this contact is necessary, but it will fall out without that bolt in place. 3. The actual holes in the metal piece through which the sleeves should slide were too small. I took a drill bit and by hand worked them wide enough so I could get the sleeves in, but it still makes me question if I have the right part. 4. Dog, recovering from ACL surgery, is no help at all. Has anyone else been successful doing this on an early car with this specific part (from this vendor) and do you recommend a different part/vendor? Thanks for your help. Winter's coming. I'd like to be able to clean the windshield. |
BeatNavy |
Sep 28 2014, 04:19 PM
Ok, well that would make some sense, I suppose. So you think it's held in only by the metal sleeve? I did find on the floor a similar contact piece that must be from my old switch, but I don't know how it was held in place (apparently not very well).
So has anyone with an early car done this conversion with this part (or used something different)? |
HalfMoon |
Sep 28 2014, 09:27 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Ok, well that would make some sense, I suppose. So you think it's held in only by the metal sleeve? I did find on the floor a similar contact piece that must be from my old switch, but I don't know how it was held in place (apparently not very well). So has anyone with an early car done this conversion with this part (or used something different)? I tried this conversion on my 73 with that part (ordered from CIP1) with no success. I actually had an electrical engineer (one of our members here) help me. No matter what we did it would blow fuse eight every single time when the switch was actually installed in the column. Outside the column it could work (after we discovered pin 2 and 3 are reversed on all of them-I actually ordered two). Compare very closely your original switch and the points of contact with the new switch and you will discover this. I never did get it to work and simply repaired my old original switch (easier to do than ya think-a common fault problem. PM me if anyone wants to know the exact fix) I would NOT recommend this part for this mod. Addedum-the nut and screw are deffinately for shipping and are to be removed on install. Here's the thread http://www.914world.com/bbs2/index.php?act...=2&t=238223 You'll have to get a few pages into the post before you see where this switch comes into the discussion but I can assure you, you'll want to read it. Post 47 is where it gets very applicable to this thread. |
BeatNavy |
Sep 29 2014, 07:23 AM
I tried this conversion on my 73 with that part (ordered from CIP1) with no success. I actually had an electrical engineer (one of our members here) help me. No matter what we did it would blow fuse eight every single time when the switch was actually installed in the column. Outside the column it could work (after we discovered pin 2 and 3 are reversed on all of them-I actually ordered two). Compare very closely your original switch and the points of contact with the new switch and you will discover this. I never did get it to work and simply repaired my old original switch (easier to do than ya think-a common fault problem. PM me if anyone wants to know the exact fix) I would NOT recommend this part for this mod. Addedum-the nut and screw are deffinately for shipping and are to be removed on install. Here's the thread http://www.914world.com/bbs2/index.php?act...=2&t=238223 You'll have to get a few pages into the post before you see where this switch comes into the discussion but I can assure you, you'll want to read it. Post 47 is where it gets very applicable to this thread. Ahhh...ok, now I only feel like three quarters of a noob. This helps me, although, just like you, I'm still left with a stock solution (actually less than stock, since the tubes inside the steering column are gone). At this point in fact I'm probably lucky if my old switch works (good thing I found that grounding contact on the floor). You went through a real odyssey trying to solve your problem. What you experienced in your thread looks similar to what this guy experienced HERE. I was trying to understand what his solution was, but it wasn't completely clear, and the 924 switch is supposed to be "plug and play." Does this look similar to what you experienced (he talks about how he solved the blown fuse issue)? Also, did notice that the pins were in different order on the new switch. Just another thing that annoyed me with the "plug and play" solution. Thanks for your help Dave. You're only about an hour from me. I think we met briefly at the East Coast Cookout in August at Mark's. Thanks, jt914-6. I may be interested in your solution, but I'm not 100% ready to give up on this general approach. At least not yet. |
HalfMoon |
Sep 29 2014, 09:03 AM
I tried this conversion on my 73 with that part (ordered from CIP1) with no success. I actually had an electrical engineer (one of our members here) help me. No matter what we did it would blow fuse eight every single time when the switch was actually installed in the column. Outside the column it could work (after we discovered pin 2 and 3 are reversed on all of them-I actually ordered two). Compare very closely your original switch and the points of contact with the new switch and you will discover this. I never did get it to work and simply repaired my old original switch (easier to do than ya think-a common fault problem. PM me if anyone wants to know the exact fix) I would NOT recommend this part for this mod. Addedum-the nut and screw are deffinately for shipping and are to be removed on install. Here's the thread http://www.914world.com/bbs2/index.php?act...=2&t=238223 You'll have to get a few pages into the post before you see where this switch comes into the discussion but I can assure you, you'll want to read it. Post 47 is where it gets very applicable to this thread. Ahhh...ok, now I only feel like three quarters of a noob. This helps me, although, just like you, I'm still left with a stock solution (actually less than stock, since the tubes inside the steering column are gone). At this point in fact I'm probably lucky if my old switch works (good thing I found that grounding contact on the floor). You went through a real odyssey trying to solve your problem. What you experienced in your thread looks similar to what this guy experienced HERE. I was trying to understand what his solution was, but it wasn't completely clear, and the 924 switch is supposed to be "plug and play." Does this look similar to what you experienced (he talks about how he solved the blown fuse issue)? Also, did notice that the pins were in different order on the new switch. Just another thing that annoyed me with the "plug and play" solution. Thanks for your help Dave. You're only about an hour from me. I think we met briefly at the East Coast Cookout in August at Mark's. Thanks, jt914-6. I may be interested in your solution, but I'm not 100% ready to give up on this general approach. At least not yet. Yep we did! (Meet at the cookout) (IMG:style_emoticons/default/biggrin.gif) I remember looking at that thread and not exactly understanding what he did to solve the problem (IMG:style_emoticons/default/dry.gif) As an aside, CIP1 has a new part (not the economy lever, the "qaulity lever") and I may order it (they issued me a full credit for the "economy lever") to see if it's somehow or another different. Here it is http://www2.cip1.com/ProductDetails.asp?Pr...2D953%2D519%2DG I like the switch noted above as a solution but frankly that's too rich for my blood. Momentary switched at radio shack would suffice and less than 5 bux. True, no intermittent feature but I can't say I need that feature bad enough to warrant 75 bux. |
Lo-Fi Version | Time is now: 14th May 2024 - 02:08 PM |
