Wiper Switch Conversion, Different for Early Cars? What am I missing? |
BeatNavy |
Sep 28 2014, 01:45 PM
So today was going to be a good day to do the wiper switch upgrade as my car's up on jackstands for brake issues and probably will be there for a few days. I was following the Pelican Article which describes itself pertaining to '74 (I've got a '72). But I've read through a lot articles on this, and I don't recall seeing any distinction between early/late cars. I ordered this 924 switch (part number 111953519G as per the article).
Anyway, once I started the process I ran into several issues which have me stumped. First of all, the quality overall seems sketchy. I had seen the caveats on the quality of this one, but even then the quality seemed suspect to the point that I'm not sure it would work at all. Then I ran into the following additional issues as annotated in the picture below: 1. The layout is different than what I had seen in other pictures, and the wire colors did not match the old switch. There's a contact anchored to the outside of the switch that I have seen in other pictures on the inside....which wouldn't bother me except... 2. ...it's held in place by a bolt and nut going through one of the holes that should hold one of the four metal sleeves that hold the turn signal and wiper assemblies together. WTF? I assume that this contact is necessary, but it will fall out without that bolt in place. 3. The actual holes in the metal piece through which the sleeves should slide were too small. I took a drill bit and by hand worked them wide enough so I could get the sleeves in, but it still makes me question if I have the right part. 4. Dog, recovering from ACL surgery, is no help at all. Has anyone else been successful doing this on an early car with this specific part (from this vendor) and do you recommend a different part/vendor? Thanks for your help. Winter's coming. I'd like to be able to clean the windshield. |
BeatNavy |
Sep 29 2014, 09:25 AM
Cool, thanks Dave! I may call CIP1 and give "the business" a bit and see if I can get an upgrade as well.
I've been reading that EV Wiper hack guy's solution carefully and I think I'm a little closer to understanding what he did (but it's real hard to follow). If I understand him correctly, too, there's an unused wire in the harness and connector that you can use for the power source (without having to tap into something else). Car's going to be on jackstands for a few days anyway while I wait for the new master cylinder to arrive... (IMG:style_emoticons/default/sad.gif) |
HalfMoon |
Sep 29 2014, 09:58 AM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Cool, thanks Dave! I may call CIP1 and give "the business" a bit and see if I can get an upgrade as well. I've been reading that EV Wiper hack guy's solution carefully and I think I'm a little closer to understanding what he did (but it's real hard to follow). If I understand him correctly, too, there's an unused wire in the harness and connector that you can use for the power source (without having to tap into something else). Car's going to be on jackstands for a few days anyway while I wait for the new master cylinder to arrive... (IMG:style_emoticons/default/sad.gif) Hmmm...well that's true enough. Pin 5 of the column harness is un-used and was placed there by the factory for the optional intermittent/washer, but sadly that's not the problem. The switch itself doesn't/didn't work (at least the economy one from CIP1) on my car. I think what he did (essentially) was re-wire the switch and remove the rear leaf component, but it's kinda hard to follow what he did.... It's possible a real OEM 924 switch could work but they're NLA. I wonder if anyone has some closeup images of a real switch? I'm pretty sure we'll find a difference of some kind. I've been waiting for the guy I sent my economy switch to for testing results on his car. If the switch fails in his application along with the same results I had (fuse blowing at 8 when switch installed in the column) then we'll all know for sure that the CIP1 economy switch won't work. If he has no trouble with the install then I'll assume I have a problem and it wasn't switch related. Seems like alot of trouble to have a column switch, eh? |
Lo-Fi Version | Time is now: 14th May 2024 - 01:10 PM |
