Wiper Switch Conversion, Different for Early Cars? What am I missing? |
BeatNavy |
Sep 28 2014, 01:45 PM
So today was going to be a good day to do the wiper switch upgrade as my car's up on jackstands for brake issues and probably will be there for a few days. I was following the Pelican Article which describes itself pertaining to '74 (I've got a '72). But I've read through a lot articles on this, and I don't recall seeing any distinction between early/late cars. I ordered this 924 switch (part number 111953519G as per the article).
Anyway, once I started the process I ran into several issues which have me stumped. First of all, the quality overall seems sketchy. I had seen the caveats on the quality of this one, but even then the quality seemed suspect to the point that I'm not sure it would work at all. Then I ran into the following additional issues as annotated in the picture below: 1. The layout is different than what I had seen in other pictures, and the wire colors did not match the old switch. There's a contact anchored to the outside of the switch that I have seen in other pictures on the inside....which wouldn't bother me except... 2. ...it's held in place by a bolt and nut going through one of the holes that should hold one of the four metal sleeves that hold the turn signal and wiper assemblies together. WTF? I assume that this contact is necessary, but it will fall out without that bolt in place. 3. The actual holes in the metal piece through which the sleeves should slide were too small. I took a drill bit and by hand worked them wide enough so I could get the sleeves in, but it still makes me question if I have the right part. 4. Dog, recovering from ACL surgery, is no help at all. Has anyone else been successful doing this on an early car with this specific part (from this vendor) and do you recommend a different part/vendor? Thanks for your help. Winter's coming. I'd like to be able to clean the windshield. |
HalfMoon |
Sep 29 2014, 10:13 AM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Interesting. I just noticed something different between the switch that guy was working on in the thread
http://914electric.wordpress.com/2011/04/2...er-switch-hack/ The economy switch available from CIP1 now is different that what he was working on. The one he was working on has all 6 wires going through the J-harness, the ones CIP1 has now DOES NOT. The trigger wire for the wash is now off to the side outside of the J-harness and the contact point (internally) for that wire looks very different than that what he was working with. |
BeatNavy |
Sep 29 2014, 10:20 AM
Interesting. I just noticed something different between the switch that guy was working on in the thread http://914electric.wordpress.com/2011/04/2...er-switch-hack/ The economy switch available from CIP1 now is different that what he was working on. The one he was working on has all 6 wires going through the J-harness, the ones CIP1 has now DOES NOT. The trigger wire for the wash is now off to the side outside of the J-harness and the contact point (internally) for that wire looks very different than that what he was working with. (IMG:style_emoticons/default/agree.gif) That's part of what was throwing me off looking at his thread and my switch. I'm not sure what that means in terms of making this a workable solution, but when you're like me and trying to follow someone's instructions step-by-step it really puts me into full monkey tilt when I see something that's different from what I have. I suppose the alternative is to try to actually grasp what's happening and what I'm trying to do so I can adjust as needed. But that takes effort (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 06:27 AM |
