Wiper Switch Conversion, Different for Early Cars? What am I missing? |
BeatNavy |
Sep 28 2014, 01:45 PM
So today was going to be a good day to do the wiper switch upgrade as my car's up on jackstands for brake issues and probably will be there for a few days. I was following the Pelican Article which describes itself pertaining to '74 (I've got a '72). But I've read through a lot articles on this, and I don't recall seeing any distinction between early/late cars. I ordered this 924 switch (part number 111953519G as per the article).
Anyway, once I started the process I ran into several issues which have me stumped. First of all, the quality overall seems sketchy. I had seen the caveats on the quality of this one, but even then the quality seemed suspect to the point that I'm not sure it would work at all. Then I ran into the following additional issues as annotated in the picture below: 1. The layout is different than what I had seen in other pictures, and the wire colors did not match the old switch. There's a contact anchored to the outside of the switch that I have seen in other pictures on the inside....which wouldn't bother me except... 2. ...it's held in place by a bolt and nut going through one of the holes that should hold one of the four metal sleeves that hold the turn signal and wiper assemblies together. WTF? I assume that this contact is necessary, but it will fall out without that bolt in place. 3. The actual holes in the metal piece through which the sleeves should slide were too small. I took a drill bit and by hand worked them wide enough so I could get the sleeves in, but it still makes me question if I have the right part. 4. Dog, recovering from ACL surgery, is no help at all. Has anyone else been successful doing this on an early car with this specific part (from this vendor) and do you recommend a different part/vendor? Thanks for your help. Winter's coming. I'd like to be able to clean the windshield. |
HalfMoon |
Sep 29 2014, 03:39 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Oh! ANd also as an aside, in his thread he was getting a blown fuse whenever he activated the washer switch. In my application, I would blow fuse 8 if the switch was simply installed in the column and I turned my ignition key on.
Just an fyi. If you get this to work I'd really like to know how? Lemme bring my car and switch down to your place and show me k? Or if you'd like a lil drive in the country, c'mon up. I'll press us some java! Cheers, D |
BeatNavy |
Sep 29 2014, 04:00 PM
Oh! ANd also as an aside, in his thread he was getting a blown fuse whenever he activated the washer switch. In my application, I would blow fuse 8 if the switch was simply installed in the column and I turned my ignition key on. Just an fyi. If you get this to work I'd really like to know how? Lemme bring my car and switch down to your place and show me k? Or if you'd like a lil drive in the country, c'mon up. I'll press us some java! Cheers, D Hey Dave, yeah, that would be awesome. One way or another we'll get together. Nice drive out Route 7 and Route 9! I'm looking for wire/connection 91 on the schematic but don't see it. I'll dig around under the front trunk cowl area and find this wire (although the idea of that wire "conveniently" being there is too...convenient, and nothing is "convenient" on a 914!). If I can find that wire and it has 12v when I'm activating the switch that'll be the ticket. Thanks for all your help! |
HalfMoon |
Sep 29 2014, 04:46 PM
Oh! ANd also as an aside, in his thread he was getting a blown fuse whenever he activated the washer switch. In my application, I would blow fuse 8 if the switch was simply installed in the column and I turned my ignition key on. Just an fyi. If you get this to work I'd really like to know how? Lemme bring my car and switch down to your place and show me k? Or if you'd like a lil drive in the country, c'mon up. I'll press us some java! Cheers, D Hey Dave, yeah, that would be awesome. One way or another we'll get together. Nice drive out Route 7 and Route 9! I'm looking for wire/connection 91 on the schematic but don't see it. I'll dig around under the front trunk cowl area and find this wire (although the idea of that wire "conveniently" being there is too...convenient, and nothing is "convenient" on a 914!). If I can find that wire and it has 12v when I'm activating the switch that'll be the ticket. Thanks for all your help! It was 91 on the schematic for a 1973. Might be different on other year models (IMG:style_emoticons/default/sad.gif) The fact that you've gotten yours installed without blowing fuse 8 is miles ahead of my nightmare. Be grateful grasshoppa |
Lo-Fi Version | Time is now: 14th May 2024 - 12:12 PM |
