Help: Car won't turn off, ...unless I pull the coil wire |
boxsterfan |
Sep 28 2014, 03:45 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Getting my car back together after replacing the fuel pump with a 2-port Bosch 69133 unit from Napa.
Car starts as normal, but when I turn her off she just keeps running. I can remove the key from ignition and she keeps running. And of course, this isn't some sort of overrun condition....actual running. Pull the coil wire and she dies as expected. Other notes, fuel pump is wired to switch power up front (previous owner did this). :dunno: |
Mike Bellis |
Sep 28 2014, 05:31 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
messix |
Sep 28 2014, 05:50 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
Mike Bellis |
Sep 28 2014, 05:54 PM
the diagram for a '74 car might be better to work off of. this one is an early '73 OK, but this one confuses some people. (IMG:style_emoticons/default/biggrin.gif) |
boxsterfan |
Sep 28 2014, 06:03 PM
the diagram for a '74 car might be better to work off of. this one is an early '73 OK, but this one confuses some people. (IMG:style_emoticons/default/biggrin.gif) I don't see any choice but to take the tank out again next weekend and start over. Of all things, I did take the battery to chassis ground cable off last weekend and cleaned it up. I just took that off again, had a look and put it back on. It's actually cleaner and nicer than it was before. But the problem still persists... (IMG:style_emoticons/default/headbang.gif) Who knows? Maybe it is the tranny ground strap. The car has been jacked up on its front wheels for a couple weeks now. Maybe that wiggled the trans ground strap loose (or it even broke). Of course, that's really just wishful thinking on my part hoping not to have to take the tank apart and out again. So before I take the tank out next weekend, how can I check the ground at the pump with a voltmeter? |
Lo-Fi Version | Time is now: 17th May 2024 - 05:35 AM |
