Help: Car won't turn off, ...unless I pull the coil wire |
boxsterfan |
Sep 28 2014, 03:45 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Getting my car back together after replacing the fuel pump with a 2-port Bosch 69133 unit from Napa.
Car starts as normal, but when I turn her off she just keeps running. I can remove the key from ignition and she keeps running. And of course, this isn't some sort of overrun condition....actual running. Pull the coil wire and she dies as expected. Other notes, fuel pump is wired to switch power up front (previous owner did this). :dunno: |
57lincolnman |
Sep 28 2014, 08:56 PM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
I had this problem and it was the ignition switch itself. The plastic ring cracks inside these and can cause this problem. Do you notice that there isn't the usual type of resistance in the switch? Hint: you can just stall the engine by letting out the clutch. It's easy to access (if you don't have a/c) with the access panel under the steering wheel.
boxsterfan |
Sep 28 2014, 09:40 PM
I had this problem and it was the ignition switch itself. The plastic ring cracks inside these and can cause this problem. Do you notice that there isn't the usual type of resistance in the switch? Hint: you can just stall the engine by letting out the clutch. It's easy to access (if you don't have a/c) with the access panel under the steering wheel. I'm starting the car (when it was starting earlier today) with gear in neutral and no clutch depressed. Ignition switch does turn freely, but I don't have anything to compare it too (ie. a brand new one turning "not so freely"). |
Lo-Fi Version | Time is now: 17th May 2024 - 04:06 AM |
