Door Panel Reconstruction, Passenger Side |
EdwardBlume |
Sep 28 2014, 07:31 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
The passenger arm rest has an upper bolt in the door, a lower bolt in the door, and then two more lower bolts lined up.
It looks like the last two bolts are fixed in the door panel. Does anyone know how these are fixed to the door panels? Any pictures? Thanks, R |
rjames |
Sep 28 2014, 08:40 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
The passenger arm rest has an upper bolt in the door, a lower bolt in the door, and then two more lower bolts lined up. It looks like the last two bolts are fixed in the door panel. Does anyone know how these are fixed to the door panels? Any pictures? Thanks, R On my '75, the two lower right bolts went directly into the metal of the door. But I wouldn't be surprised if this wasn't correct. Taking off the panel to look is easy though. Just remove all the armrest bolts. The interior door handle and window crank (1 screw for each), carefully pop the clips on the outer edge of the panel and then slide the whole panel upwards to remove. Armed with replacement vynil and a staple gun, they are fairly easy to redo. |
Lo-Fi Version | Time is now: 19th May 2024 - 12:41 AM |
