Door Panel Reconstruction, Passenger Side |
EdwardBlume |
Sep 28 2014, 07:31 PM
The passenger arm rest has an upper bolt in the door, a lower bolt in the door, and then two more lower bolts lined up.
It looks like the last two bolts are fixed in the door panel. Does anyone know how these are fixed to the door panels? Any pictures? Thanks, R |
bluhun |
Sep 28 2014, 10:10 PM
Member Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California |
The passenger arm rest has an upper bolt in the door, a lower bolt in the door, and then two more lower bolts lined up. It looks like the last two bolts are fixed in the door panel. Does anyone know how these are fixed to the door panels? Any pictures? Thanks, R There are a couple of nuts attached to the backside of the door panel. |
EdwardBlume |
Sep 28 2014, 11:07 PM
The passenger arm rest has an upper bolt in the door, a lower bolt in the door, and then two more lower bolts lined up. It looks like the last two bolts are fixed in the door panel. Does anyone know how these are fixed to the door panels? Any pictures? Thanks, R There are a couple of nuts attached to the backside of the door panel. Thanks. How is it attached? |
Kansas 914 |
Sep 29 2014, 09:37 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
The passenger arm rest has an upper bolt in the door, a lower bolt in the door, and then two more lower bolts lined up. It looks like the last two bolts are fixed in the door panel. Does anyone know how these are fixed to the door panels? Any pictures? Thanks, R There are a couple of nuts attached to the backside of the door panel. Thanks. How is it attached? I thought it was a special nut with a clip on it? Like some kind of a speed nut. |
Lo-Fi Version | Time is now: 19th May 2024 - 12:14 AM |
