Sad day for this 918 owner, Torched at the gas pump |
Maltese Falcon |
Sep 28 2014, 11:43 PM
Advanced Member Group: Members Posts: 4,645 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Looks like this new 918 owner had an awful experience at the gas station.
Jalopnik has the story, apparently the driver started to move away from the pump + still had the nozzle attached to the car (IMG:style_emoticons/default/sad.gif) The fuel filler is in the area near the sail pillar, and the twin hot exhaust exits are up top of the engine grille. |
Woody |
Oct 1 2014, 06:27 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Just for what its worth, the fuel door wont even open unless the car is turned off. On the 918, since it is a hybrid that does not run the engine all the time, a different type of fuel vapor recovery system is required. On a normal car the fuel tank vapor is vented to the carbon canister and the intake manifold. On this car, since it can drive awhile without running the engine, the tank is designed to hold pressure from the fuel vapors. When you fuel the car, it has to drop the pressures in the tank before the lid will even open.
Lo-Fi Version | Time is now: 15th May 2024 - 11:35 PM |
