Dual carbs, Fuel delivery |
arkitect |
Sep 29 2014, 05:31 AM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
I've been working on my dual carb setup for awhile now. Thought I would have them sorted by now. Having trouble with getting fuel to the passenger side carb. I can see the fuel going into the driver side fine but the passenger side just barely one barrel getting fuel.
I am using the Weber IDF40 carbs with a faucet electric pump. Maybe not enough fuel pressure? After the fuel filter I have a single to dual fitting to split the fuel line to the carbs. Stronger pressure to one side? Any comments would be helpful. Thanks. Dave |
jsaum |
Sep 30 2014, 10:34 AM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
Are you using a fuel pressure regulator? Here's a picture of my set up with EMPI 34's on a 1.8. I used a T fitting and didn't have any issues.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 10th May 2024 - 05:55 AM |
