Dual carbs, Fuel delivery |
arkitect |
Sep 29 2014, 05:31 AM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
I've been working on my dual carb setup for awhile now. Thought I would have them sorted by now. Having trouble with getting fuel to the passenger side carb. I can see the fuel going into the driver side fine but the passenger side just barely one barrel getting fuel.
I am using the Weber IDF40 carbs with a faucet electric pump. Maybe not enough fuel pressure? After the fuel filter I have a single to dual fitting to split the fuel line to the carbs. Stronger pressure to one side? Any comments would be helpful. Thanks. Dave |
arkitect |
Sep 30 2014, 08:22 PM
Here is a shot of both carbs. The driver side carb shoots a nice stream of fuel to both barrels. The passenger side carb, not so much - the barrel closest to the fire wall, dribbles out and the rear barrel has no fuel coming out of the jet.
Here is a close up of the driver's side, the jet is visible in the left barrel, bottom. |
Lo-Fi Version | Time is now: 9th May 2024 - 08:30 PM |
