Dual carbs, Fuel delivery |
arkitect |
Sep 29 2014, 05:31 AM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
I've been working on my dual carb setup for awhile now. Thought I would have them sorted by now. Having trouble with getting fuel to the passenger side carb. I can see the fuel going into the driver side fine but the passenger side just barely one barrel getting fuel.
I am using the Weber IDF40 carbs with a faucet electric pump. Maybe not enough fuel pressure? After the fuel filter I have a single to dual fitting to split the fuel line to the carbs. Stronger pressure to one side? Any comments would be helpful. Thanks. Dave |
arkitect |
Sep 30 2014, 09:20 PM
Thanks for the suggestions. I was thinking along the same line, blocking the fuel line to the driver side carb and see if there is a change.
Switching the carbs, not so easy. I've had the passenger off and on so many times that I'm getting quicker with it. The driver side carb didn't go on as easy and will be a major pain to take off. It would be nice to actually drive this car instead of it being a yard ornament. Dave |
Lo-Fi Version | Time is now: 10th May 2024 - 11:26 AM |
