Dual carbs, Fuel delivery |
arkitect |
Sep 29 2014, 05:31 AM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
I've been working on my dual carb setup for awhile now. Thought I would have them sorted by now. Having trouble with getting fuel to the passenger side carb. I can see the fuel going into the driver side fine but the passenger side just barely one barrel getting fuel.
I am using the Weber IDF40 carbs with a faucet electric pump. Maybe not enough fuel pressure? After the fuel filter I have a single to dual fitting to split the fuel line to the carbs. Stronger pressure to one side? Any comments would be helpful. Thanks. Dave |
stugray |
Sep 30 2014, 11:10 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Another possibility is a stuck float.
you can pull the tops and see if the bowls are full, but you would need to do that to check the accel pump input valve/jet anyway. You 'should' have a set of spare gaskets before you pop the top one one of those. |
Lo-Fi Version | Time is now: 10th May 2024 - 10:14 AM |
