914 Cam Gear number |
Sea Dragon 914 |
Sep 29 2014, 09:36 PM
Member Group: Members Posts: 114 Joined: 26-February 03 Member No.: 358 Region Association: Northern California |
What is the number that is stamped on the Cam gear? I have one that is "0" and another that is "-2". Can I use the cams interchangeably when rebuilding my engine or do I have to go with the same gear number?
Thx, SD |
Dave_Darling |
Sep 30 2014, 12:34 PM
914 Idiot Group: Members Posts: 14,985 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I don't think the numbered cam gears have been available for quite a while. All of the aftermarket cam gears are "0" anyway, so it can't be that bad to just use a "0".
Don't reuse the cams. Chances are pretty good that they're at least halfway worn out by now; going with a new one from a quality manufacturer (and new matching lifters!) only makes sense. --DD |
Sea Dragon 914 |
Sep 30 2014, 01:35 PM
Thanks for the info.
I have a spare -2 cam that I had checked and re-ground by Elgins and the case I split has a 0 cam in it so I was thinking of just using the -2 cam. Maybe I'll send the 0 cam up to Elgins to have checked and re-ground. I have time as I still haven't ordered a piston set yet. I don't think the numbered cam gears have been available for quite a while. All of the aftermarket cam gears are "0" anyway, so it can't be that bad to just use a "0". Don't reuse the cams. Chances are pretty good that they're at least halfway worn out by now; going with a new one from a quality manufacturer (and new matching lifters!) only makes sense. --DD |
Lo-Fi Version | Time is now: 14th May 2024 - 03:21 AM |
