Reviving the herd, Or, "How to lose money and friends and anger the wife" |
paxton |
Oct 2 2014, 08:41 AM
Newbie Group: Members Posts: 33 Joined: 5-September 14 From: Huntsville, AL Member No.: 17,865 Region Association: South East States |
See my first post:
http://www.914world.com/bbs2/index.php?showtopic=243052 I won't clutter up the board with a bunch of threads, so I'll contain my questions to this one. First up is the green machine. Kind of more like sunflower than green, but I digress. The green machine has no battery. It will not start, obviously. But first a little story. For the past few days, the keys for the green machine have been missing. I have a devious little boy who likes to grab things and put them away in his many toy boxes/behind the couch/underneath things I didn't know there was an underneath to. I also just sold an old 412 and thought maybe I left them in there for some odd reason. I had turned the house and the garage upside down. No keys. I gather the family (which includes 3 older kids who always want money) and I said whoever finds the keys in this house will get $50. They never worked so hard. My wife wanted money to (surprise!) so she was in on the hunt too. On a whim, my wife went out to the car and looked in the ignition. Silly woman. That car doesn't even have a battery in it. Why would you look in... "I found them!" she yelled. What? You found the keys? IN THE IGNITION???? Of course they would be in the ignition of a non-running car that doesn't have a battery. Of course... Then I remembered: I sold the 412 and moved the green machine in its place. I had to turn the key to keep the steering wheel from locking. So I'm the idiot and I'm out $50. Back to the car. The previous owner told me it will start (and run) if you use some starting fluid. If you turn the engine off, it will not start again, until you use starting fluid. My plan is to drain the gas, refuel, replace plugs, wires, and cap (at least), and then check each of the injectors. Change oil and new filter. Any other guidance? |
r_towle |
Oct 2 2014, 08:18 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Well, you need to now see if it's coming out of the injectors.
What I do to get it done quick is pull all four injectors by removing the little 10 mm nut on each one, but leave the electrics and fuel hoses connected. Put the,end of each injector into some little glass baby food jars. Remove the main, middle ignition coil wire from the middle of the distributor and from the coil....get it out of the car. Turn over the motor for about 20-30seconds Go see if there is fuel in each jar, and it's the same amount. Rich |
paxton |
Oct 3 2014, 02:43 PM
Well, you need to now see if it's coming out of the injectors. What I do to get it done quick is pull all four injectors by removing the little 10 mm nut on each one, but leave the electrics and fuel hoses connected. Put the,end of each injector into some little glass baby food jars. Remove the main, middle ignition coil wire from the middle of the distributor and from the coil....get it out of the car. Turn over the motor for about 20-30seconds Go see if there is fuel in each jar, and it's the same amount. Rich And the motor doesn't turn over. Starter issue (wiring, relay, bad starter, etc.)... Who knows. But cooler weather and fall break means I should have time to make a dent. Not literally, I hope... |
Lo-Fi Version | Time is now: 17th May 2024 - 03:55 PM |
