| earossi |
Oct 2 2014, 05:09 PM
Member ![]() ![]() Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
I need to replace the wire cable and its sheath that operates the front trunk hood. Is there an "easy" way to do this? Any pitfalls? Better yet, is there a DIY writeup out there. I used the Search feature but nothing turned up.
earossi Front Hood Lock Cable Release Replacement Oct 2 2014, 05:09 PM
r_towle I believe it is a tube that could be replaced with... Oct 2 2014, 05:20 PM
earossi
I believe it is a tube that could be replaced wit... Oct 2 2014, 06:34 PM
Johny Blackstain If you're not going to replace with stock part... Oct 2 2014, 05:42 PM
hndyhrr If you can find it long enough from a bike shop I ... Oct 2 2014, 06:19 PM
r_towle The cable needs to be in a Boleyn, or sheath yes, ... Oct 2 2014, 06:27 PM
Johny Blackstain
The cable needs to be in a Boleyn, or sheath yes,... Oct 2 2014, 06:31 PM
bdstone914 The end of the original cable has a threaded end t... Oct 2 2014, 06:35 PM
earossi So, the plastic sheathe is a length of plastic tub... Oct 2 2014, 06:42 PM
mepstein place a wtb in the classifieds and get a real repl... Oct 2 2014, 08:03 PM
Chris H. 914rubber sells the cable itself all set up correc... Oct 2 2014, 08:10 PM
earossi
914rubber sells the cable itself all set up corre... Oct 2 2014, 09:07 PM
[quote name='Chris H.' post='2093171' date='Oct 2... Oct 2 2014, 09:15 PM
earossi
[quote name='Chris H.' post='2093171' date='Oct ... Oct 2 2014, 10:59 PM
[quote name='mepstein' post='2093216' date='Oct 2... Oct 3 2014, 04:56 AM
HalfMoon No one's told you the fun part.
Getting it adj... Oct 2 2014, 08:31 PM
Getting it ad... Oct 2 2014, 08:36 PM
jeffdon
Getting it a... Oct 2 2014, 08:38 PM
[quote name='mepstein' post='2093197' date='Oct 2... Oct 2 2014, 09:12 PM
earossi OK. I played with the car tonight and answered on... Oct 2 2014, 08:56 PM
jsh
I need to replace the wire cable and its sheath t... Oct 2 2014, 09:19 PM
Steve I just did mine also. Bought it all from Pelican.... Oct 2 2014, 09:26 PM
earossi OK. All done......and successfully! It was a... Oct 3 2014, 03:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:47 PM |
