Anyone tried an aircooled Flat 8, With two fours? |
r_towle |
Jan 28 2005, 12:49 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Has anyone tried to build a flat 8 with two type 4 motors?
Theoretical questions. Assumptions 2 motors each producing 100 HP and 100 Lb/ft of Torque The motors are end to end, front to rear. The cranks are fastened together either bolted or welded. 1) Would you get 200hp and 200 lb/ft or torque? or is there some multiplier...seems like you would produce more torque.. 2) could it be done with a single ignition system available for sale off the shelf. 3) could you do it without two distributors? crank fired ignition system..I am thinking that there could be a wheel placed in between the motors to give you something to time from. 4) I am assuming either a nice FI system, or four carbs. Has anyone done this? I would like to see some articles or web pages if this has been done in the aircooled world... Thanx in advance Rich |
eeyore |
Jan 28 2005, 01:22 PM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
Double displacement does not usually equal double torque or horsepower. Not sure why.
In WWII, Pratt & Whitney took 2 14 cylinder radials and joined them onto a single case, resulting in a 28 cylinder that made 50% more HP. In the '90s Honda simply upped the size of a 600cc four to 900cc and got 20% more power (50% more displacement). Granted, the stock T4 is restricted, so using a RAT 2270 as a basis, maybe 250 HP would come from a T4x2. Just guessing. |
