Anyone tried an aircooled Flat 8, With two fours? |
r_towle |
Jan 28 2005, 12:49 PM
Custom Member Group: Members Posts: 24,564 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Has anyone tried to build a flat 8 with two type 4 motors?
Theoretical questions. Assumptions 2 motors each producing 100 HP and 100 Lb/ft of Torque The motors are end to end, front to rear. The cranks are fastened together either bolted or welded. 1) Would you get 200hp and 200 lb/ft or torque? or is there some multiplier...seems like you would produce more torque.. 2) could it be done with a single ignition system available for sale off the shelf. 3) could you do it without two distributors? crank fired ignition system..I am thinking that there could be a wheel placed in between the motors to give you something to time from. 4) I am assuming either a nice FI system, or four carbs. Has anyone done this? I would like to see some articles or web pages if this has been done in the aircooled world... Thanx in advance Rich |
Mueller |
Jan 28 2005, 01:03 PM
yep, a few have been done........I know I've posted pictures as a well as a few others....
for a 914 application, the motor wouldn't fit unless you moved the assembly back a few inches...even without the cooling fan, I don't think it would fit in the stock location for the cost/time/ it would take to make one, there are a dozen better engine choices unless one just wants to do it for the novelty of doing it.... since it's already been done a few times, there is no novelty in it....nothing ground breaking....kinda boring (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
