Anyone tried an aircooled Flat 8, With two fours? |
r_towle |
Jan 28 2005, 12:49 PM
Custom Member Group: Members Posts: 24,560 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Has anyone tried to build a flat 8 with two type 4 motors?
Theoretical questions. Assumptions 2 motors each producing 100 HP and 100 Lb/ft of Torque The motors are end to end, front to rear. The cranks are fastened together either bolted or welded. 1) Would you get 200hp and 200 lb/ft or torque? or is there some multiplier...seems like you would produce more torque.. 2) could it be done with a single ignition system available for sale off the shelf. 3) could you do it without two distributors? crank fired ignition system..I am thinking that there could be a wheel placed in between the motors to give you something to time from. 4) I am assuming either a nice FI system, or four carbs. Has anyone done this? I would like to see some articles or web pages if this has been done in the aircooled world... Thanx in advance Rich |
r_towle |
Jan 28 2005, 01:05 PM
i was hoping you would answer...you always think outside the box...
So what about the torque numbers...is it simply double??? It just seems that is would be multiplied somehow.. and where would i find some pics.... Rich |
