European Parking Lights Say on Left Side, 3 fuses fell out when reaching for hood release |
Grump |
Oct 6 2014, 12:28 PM
Member Group: Members Posts: 167 Joined: 26-April 06 From: Charlottesville Va. Member No.: 5,930 Region Association: None |
While at gas station 4 days ago, I reached in to release the hood to fill the tank. I grabbed the fuse panel and 3 fuses fell out. I was a block from home so I waiting until I got home to put them back in.
I didn't pay attention to what fuses they were. After putting them back in, I noticed the left side parking lights were on. The turn lever was in the neutral position. The right side works as it should. Turn signals and hazard flasher work as they should. I have a good schematic thanks to Jeff but I lack the ability to troubleshoot this #5 fuse circuit. I don't necessarily need this "feature" and can just leave the fuse out, but it worked before and I would like to have it back to normal. I reenacted my motions, dropped the fuse panel and inspected it closely for short or grounds, dropped and changed the headlight switch and hazard switch. After 3 days I've gone as far as I can without some help. Looking for help from those who may of had a problem with this circuit. It's getting 12V from somewhere. It's a 75.. Thanks. Bill |
SirAndy |
Oct 6 2014, 12:46 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
European Parking Lights If the lever is in the neutral position, then your problem has nothing to do with the parking light option. (IMG:style_emoticons/default/shades.gif) |
Grump |
Oct 6 2014, 01:38 PM
European Parking Lights If the lever is in the neutral position, then your problem has nothing to do with the parking light option. (IMG:style_emoticons/default/shades.gif) You are correct. It's just that the right side comes on when right turn signal is on but the left stays on as long as fuse #5 is in. When light switch is pulled to parking light position, right comes on and of course, left side parking lights is on regardless of the headlight switch position. Thanks for the clarification.. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:49 PM |
