European Parking Lights Say on Left Side, 3 fuses fell out when reaching for hood release |
Grump |
Oct 6 2014, 12:28 PM
Member Group: Members Posts: 167 Joined: 26-April 06 From: Charlottesville Va. Member No.: 5,930 Region Association: None |
While at gas station 4 days ago, I reached in to release the hood to fill the tank. I grabbed the fuse panel and 3 fuses fell out. I was a block from home so I waiting until I got home to put them back in.
I didn't pay attention to what fuses they were. After putting them back in, I noticed the left side parking lights were on. The turn lever was in the neutral position. The right side works as it should. Turn signals and hazard flasher work as they should. I have a good schematic thanks to Jeff but I lack the ability to troubleshoot this #5 fuse circuit. I don't necessarily need this "feature" and can just leave the fuse out, but it worked before and I would like to have it back to normal. I reenacted my motions, dropped the fuse panel and inspected it closely for short or grounds, dropped and changed the headlight switch and hazard switch. After 3 days I've gone as far as I can without some help. Looking for help from those who may of had a problem with this circuit. It's getting 12V from somewhere. It's a 75.. Thanks. Bill |
Grump |
Oct 8 2014, 11:51 AM
Update..
There are 34 pages when searching for electrical problems. So far I've read 28 pages detailing all sorts of problems, however, none yet that helped. The majority stress the importance of checking and cleaning all grounds. I cleaned all my grounds, cleaned fuse holder, replaced every fuse with new ones, removed every bulb, removed every fuse one at a time, disconnected that circuit from light switch. The problem still exists. I'm still getting 12V at fuse #5. In tracing the path, with wire goes from fuse #5 to the light switch and then diagram says it continues to connection 67, which I believe connects under the passenger seat. This where I get lost. The relay has been bypassed. I don't see how this is providing the 12V to the left marker circuit. Any help will be greatly appreciated. |
Lo-Fi Version | Time is now: 26th May 2024 - 12:25 AM |
