914-6 Speedo flutters, Speedometer issue |
stuartgto |
Oct 12 2014, 05:00 PM
Newbie Group: Members Posts: 15 Joined: 17-April 13 From: 94070 Member No.: 15,777 Region Association: None |
Reattached the speedo/odometer 914/6 unit after odometer was fixed at PA Speedo. Now the speedometer needle flutters. It did not before being pulled to have the non-functioning odometer fixed. Speedo cable rotates when car is moving, but also can be moved with pliers when not attached to gauge. Any suggestions?
Cap'n Krusty |
Nov 6 2014, 12:05 AM
IME, cables can be damaged during installation, or while working under the dash, or simply developing a kink or bend while in place (say, someone kicks it, ir it gets forced forward or back). I'd check that before buying a cable. Gemo may be all that's out there, and I've had no problems with the dozen or so I've installed over the years.
The Cap'n |
Lo-Fi Version | Time is now: 18th May 2024 - 11:20 PM |
