new rotor is not centered in new caliper |
siverson |
Oct 12 2014, 07:32 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
it doesnt rub, but is very close. is this too close?
Attached thumbnail(s) |
siverson |
Oct 12 2014, 07:33 PM
914
siverson |
Oct 12 2014, 07:38 PM
wndsrfr |
Oct 12 2014, 08:19 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Might rub when the rotor gets hot...then it'll get even hotter! Looks a bit sketchy--where did you source the rotor & caliper??
Mike Bellis |
Oct 12 2014, 08:28 PM
What is the piston to caliper difference? They should be equal or damn near. You could always machine the caliper.
siverson |
Oct 12 2014, 09:04 PM
nevermind... figured it out. struts were powdercoated and i forgot to tape that side off. when i bolted up the other side the disc was perfectly centered.
a little file and sandpaper work and its fixed now. |
Lo-Fi Version | Time is now: 21st May 2024 - 01:04 AM |
