oil temp combo gauge bench testing, what am I doing wrong (question answered) next: calibrate the gauge |
malcolm2 |
Oct 14 2014, 09:00 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I have had this gauge for a while. I also found the complete taco plate, sender etc... to set it up. I decided to test it. I tested the sender a while back in hot water and remember getting various readings as the temp increased.
I pulled out my 12v powered drill battery, put 12v + on the + terminal of the gauge and the - on the - of the gauge. ( you can't see the - wire in the picture, but it is there) The gauge moved to where it is in the picture without the sender even being connected. It did not move once the sender was connected. Inside the temp gauge are the following #s. Far left 30, at the start of the red line 156.7 and the end of the red line 170 *C The top of the paper is what is stamped on each face of the hex and the gauge part # has been edited to what you see in the picture. 1. why is the gauge moving at room temp with or with out the sender? 2. do I have this thing hooked up right? any alternate testing suggestions? 3. do I have a matched sender & gauge? |
Dave_Darling |
Oct 15 2014, 01:30 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Just to make sure:
You know that the "G" on the back of the gauge does not stand for "ground", right? It's for "sender" (in German). So that terminal gets hooked up to the terminal on the back of the sender, and the threaded part of the sender gets hooked up to a ground. Like the ground terminal on the back of the gauge. I'm just trying to make sure of the "did you turn it on" type of questions... --DD |
Lo-Fi Version | Time is now: 18th May 2024 - 12:51 PM |
