oil temp combo gauge bench testing, what am I doing wrong (question answered) next: calibrate the gauge |
malcolm2 |
Oct 14 2014, 09:00 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I have had this gauge for a while. I also found the complete taco plate, sender etc... to set it up. I decided to test it. I tested the sender a while back in hot water and remember getting various readings as the temp increased.
I pulled out my 12v powered drill battery, put 12v + on the + terminal of the gauge and the - on the - of the gauge. ( you can't see the - wire in the picture, but it is there) The gauge moved to where it is in the picture without the sender even being connected. It did not move once the sender was connected. Inside the temp gauge are the following #s. Far left 30, at the start of the red line 156.7 and the end of the red line 170 *C The top of the paper is what is stamped on each face of the hex and the gauge part # has been edited to what you see in the picture. 1. why is the gauge moving at room temp with or with out the sender? 2. do I have this thing hooked up right? any alternate testing suggestions? 3. do I have a matched sender & gauge? |
Mblizzard |
Oct 15 2014, 07:44 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Anyone figure out Clark is an engineer?
I know some of the other gauges have some reference values printed al g the very top part of the gauge. Not sure if the combo is the same. |
malcolm2 |
Oct 16 2014, 06:29 AM
Anyone figure out Clark is an engineer? I know some of the other gauges have some reference values printed al g the very top part of the gauge. Not sure if the combo is the same. This one does have those numbers. you need to take it out to see them and they are in Celsius. The red line starts at 156.7 then there is a slight tick mark 1/2 way across the red for 170. Thanks for the vote of confidence, but i am the type of engineer that the other engineers make jokes about, an industrial engineer. (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 25th May 2024 - 06:05 AM |
