Dreaming, Thinking about starting down the 6 path |
Mblizzard |
Oct 15 2014, 04:44 PM
Not something that will ever happen but I dream of more power. The FI 2056 is fun but I just remember my old 2.0 seeming to have so much more go. It was a 71 with FI and some head work and balancing but that was all. I just remember it pulling so strong from low RPM to redline. But I just don't get that same feeling from this build.
Don't get me wrong it runs well and pulls away from many modern cars with ease. But in my mind I think it should have more punch. So I was thinking a 6 conversion was a possibility. Will keep the 2056 so I would be looking for a donor engine and all that entails. Because I am dreaming I was wondering if people had some estimates of costs, things to look out for, and suggestions of the best motor to go after? |
pilothyer |
Oct 15 2014, 04:57 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Mike......... First is more power.......Then how to transfer all that power to the road. Then how to stop better with all that power........than beefing up all the weak links to handle all that power. I fully understand though (IMG:style_emoticons/default/biggrin.gif)
Java2570 |
Oct 15 2014, 05:08 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I'd be happy with a nice 2.7 but I've heard great things about 3.0 & 3.2's. I suppose once you get the more power bug, you'll want more! About your 2056 vs. 2.0L, did you have port work done on your 2.0L heads? I *think* I remember that you had HAM rebuild the heads on your 2056??? I bought a set of his
RS+ heads and he mentions that the port shape and design of this head will get you better low to mid torque. Having run out of $$ and being a bit lazy, I haven't gotten that 2056 built yet. I'm hoping that these heads plus the Tangerine header, I'll feel a nice low to mid boost when I get it built. Good luck with the dreaming! |
sb914 |
Oct 15 2014, 06:07 PM
Surf Guru Group: Members Posts: 4,303 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Not something that will ever happen but I dream of more power. The FI 2056 is fun but I just remember my old 2.0 seeming to have so much more go. It was a 71 with FI and some head work and balancing but that was all. I just remember it pulling so strong from low RPM to redline. But I just don't get that same feeling from this build. Don't get me wrong it runs well and pulls away from many modern cars with ease. But in my mind I think it should have more punch. So I was thinking a 6 conversion was a possibility. Will keep the 2056 so I would be looking for a donor engine and all that entails. Because I am dreaming I was wondering if people had some estimates of costs, things to look out for, and suggestions of the best motor to go after? Want power ?Dream big ,sbc v8 you will get planted in your seat.pretty much no one can touch you. |
76-914 |
Oct 15 2014, 06:42 PM
A water cooled conversion is a lot more work and not for the faint of heart. Quickest way to get a 6 is to throw an air cooled 6 in it. More support will be available when doing an AC 6, as well. Water cooled SBC's are fairly well documented and supported so not as many hiccups as with some other conversions. Subaru conversions are gaining in popularity so support should grow as well.
Mblizzard |
Oct 15 2014, 06:50 PM
Will stick with the air cooled options but those V8s are something.
Oct 15 2014, 06:56 PM
Because I am dreaming I was wondering if people had some estimates of costs, things to look out for, and suggestions of the best motor to go after? A air-cooled Porsche /6 conversion will set you back $10k-$15k if you do most of the work yourself. Even if you can source a smaller /6 engine, like mentioned above the parts add up quickly. Mine cost around $15k some 10 years ago and i got the engine, transmission and exhaust for a steal back then. (IMG:style_emoticons/default/cheer.gif) |
dw914six |
Oct 15 2014, 07:12 PM
Member Group: Members Posts: 131 Joined: 18-January 14 From: Houston Member No.: 16,902 Region Association: Southwest Region |
Not something that will ever happen but I dream of more power. The FI 2056 is fun but I just remember my old 2.0 seeming to have so much more go. It was a 71 with FI and some head work and balancing but that was all. I just remember it pulling so strong from low RPM to redline. But I just don't get that same feeling from this build. Don't get me wrong it runs well and pulls away from many modern cars with ease. But in my mind I think it should have more punch. So I was thinking a 6 conversion was a possibility. Will keep the 2056 so I would be looking for a donor engine and all that entails. Because I am dreaming I was wondering if people had some estimates of costs, things to look out for, and suggestions of the best motor to go after? First, your 2.0 probably did go faster...we all weighed a lot less back in the day. (IMG:style_emoticons/default/huh.gif) Get a true bad boy 6 and live your dream Mike. You only live once. (IMG:style_emoticons/default/shades.gif) |
Oct 15 2014, 07:15 PM
bigkensteele |
Oct 15 2014, 07:16 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Your best bet is to do what I am doing. Buy your parts slowly over time when deals pop up, and most importantly, never - ever add up what you have spent. I have found it to be quite affordable that way. (IMG:style_emoticons/default/beerchug.gif)
wndsnd |
Oct 15 2014, 07:27 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I pulled over 60 studs from my 2.7 case this weekend. That did not include the expensive head studs, just perimeter and misc.
Said to myself, not alot of play cash this month. I will just go get some studs. Ha Ha Ha Ha Ha Ha Ha Ha Ha (IMG:style_emoticons/default/blink.gif) John |
rick 918-S |
Oct 15 2014, 07:31 PM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Oct 15 2014, 07:32 PM
Sell more shit
Mblizzard |
Oct 15 2014, 07:36 PM
Interesting but if it needs an oil pump that has to have other issues to go with the 151k on the car. |
wndsnd |
Oct 15 2014, 07:37 PM
mgp4591 |
Oct 15 2014, 07:40 PM
914 Guru Group: Members Posts: 5,374 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Understanding the lust for power is easy- after 8 big block musclecars I've gotten used to frying tires at will. This will be a different project for me because these cars are totally different. The handling is miles beyond any of my stock rides back in the day, not to mention the smiles per gallon. The dollar figure in the end was the make or break for me. I'd recommend getting a dollar amount in mind, what you'd pay for all that you'd want then put together and realistic estimate of costs and compare the two. Then proceed with that goal in mind but be prepared to put out more cash when needed. In the end if done right, you'll have what you want for the price you're comfortable with. Then DRIVE THE DAMN THING!!! (IMG:style_emoticons/default/driving.gif)
rick 918-S |
I have a whole new respect for the 914 2.0 cars since driving Sandy's to the RRC this years. You have to know when driving the Alien I don't even have to think about gear changes. Traction? ya.. (IMG:style_emoticons/default/confused24.gif) but more than once I pulled out to pass and had to rethink my choices. From which gear to the distance I needed to pass. Traction, braking and cornering were non-issues. (IMG:style_emoticons/default/aktion035.gif)
Driving a 4 cylinder 914 is a true driving experience. Driving the Alien is a heart pounding emotional roller coaster where you go from grinning to shear terror when you start to throttle steer through a corner. Which one is more fun? BOTH! (IMG:style_emoticons/default/assimilate.gif) (IMG:style_emoticons/default/assimilate.gif) |
carr914 |
Oct 15 2014, 07:42 PM
Racer from Birth Group: Members Posts: 118,670 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Because I am dreaming I was wondering if people had some estimates of costs, things to look out for, and suggestions of the best motor to go after? A air-cooled Porsche /6 conversion will set you back $10k-$15k if you do most of the work yourself. Even if you can source a smaller /6 engine, like mentioned above the parts add up quickly. Mine cost around $15k some 10 years ago and i got the engine, transmission and exhaust for a steal back then. (IMG:style_emoticons/default/cheer.gif) This! Better off buying a Conversion done and keeping your existing car. I could do a car cheap as I have 90% of the parts and that is why I toyed around with converting the Alaska Appearance Group car. But it is much better & easier to buy an existing Conversion. One like kconway's was perfect but you have to ready to jump - I wish I had gotten that one! |
Oct 15 2014, 07:46 PM
buy someone else's conversion car. It will cost the same as doing the conversion yourself and you will have 2 cars instead of 1 car and a bunch of parts. Plus immediate gratification vs the typical 3 year build.
patssle |
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I just finished (well...nothing is ever finished) my 3.0L conversion for $8700 and 6 months of hard but very satisfying work. A rather low price that I cheated by stealing a motor out of a project 911.... but it's very much possible. I'm still getting use to it but boy do I love the power in 2nd and 3rd gear!
Lo-Fi Version | Time is now: 17th May 2024 - 01:56 PM |
