sorting thru some issues and decided to start with cap and rotor, ** updated to 11/20 - 3 issues causing 3 overlapping problems- resolved |
DRPHIL914 |
Oct 17 2014, 04:50 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have not seen scratches like this before in a cap.; bad rotor?
- see the last post- 1 bad CHT 2. bad TPS 3. bad f.i. injector trigger points plate. NOT MPS, NOT cap, rotor(although i did replace these too) Attached thumbnail(s) |
r_towle |
Oct 29 2014, 08:17 AM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
So, a stock motor should not need any adjustment on the MPS.
If it's running lean, it's either a vacuum leak or your timing is to advanced. You could also have issues with the TPS not being installed correctly and setup to be on the correct idle circuit when at idle. If the CHT is unplugged or that wiring is compromised, the car won't start. One thing to consider, and many of us have had to deal with this... The old brittle FI wiring harness will be darn near impossible to rule out until you test every circuit with an ohm meter. Pull off the main plug from the ECU and ohm out each wire..... These old wiring harnesses will give you all sorts of issues, and they change each time you do anything new. Just touching the harness to install things can create a break. Rich |
Lo-Fi Version | Time is now: 18th May 2024 - 06:34 PM |
