sorting thru some issues and decided to start with cap and rotor, ** updated to 11/20 - 3 issues causing 3 overlapping problems- resolved |
DRPHIL914 |
Oct 17 2014, 04:50 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have not seen scratches like this before in a cap.; bad rotor?
- see the last post- 1 bad CHT 2. bad TPS 3. bad f.i. injector trigger points plate. NOT MPS, NOT cap, rotor(although i did replace these too) Attached thumbnail(s) |
dknechtly |
Oct 30 2014, 06:57 AM
Yellow 914 Group: Members Posts: 68 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None |
How's the resistance at the trigger points? It doesn't take much to make it run lean. Don't use emory cloth; it is too coarse. A note card or jeweler's cloth works.
DRPHIL914 |
Oct 30 2014, 07:28 AM
How's the resistance at the trigger points? It doesn't take much to make it run lean. Don't use emory cloth; it is too coarse. A note card or jeweler's cloth works. do you mean the injector trigger points? I have a points module (hotspark)- same as compufire. ive been running it for 4-5 years. but i have a second one and i might switch it out as part of my trial and error just to see if it makes a difference. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:04 PM |
