Too much travel clutch fork |
Kansas 914 |
Oct 19 2014, 01:45 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I have a friend that is trying to install a new (used) transaxle in his car. He is telling me that he has A LOT of free travel in the clutch fork before he feel any resistance from the T/O bearing touching the fingers on the pressure plate.
He has 3 washers behind the clutch fork pivot ball right now. What can cause significant travel of the clutch fork before resistance? The clutch has all new parts (pressure plate, disk and throw-out bearing). The only part that is not new is the cup washer in the clutch fork. He said there is only about 1/2" space between the fork and the clutch fork opening before it hits the case when trying to engage the clutch. Thanks in advance! |
orangecrate |
Oct 19 2014, 04:05 PM
Member Group: Members Posts: 152 Joined: 16-September 13 From: Apache Junction AZ Member No.: 16,394 Region Association: Southwest Region |
I just replace that cup and it made a significant difference in the slop of my clutch fork. Mine had worn through and allowed the pivot ball to wear into aluminum of the bellhousing. I put a small amount of liquid steel in the hole to take up for the wear and back up the new cup and tapped it in. Problem solved. Don't get carried away with the liquid steel. You only need enough to fill in for the wear. Too much could cause more problems.
Kansas 914 |
Oct 19 2014, 04:58 PM
I just replace that cup and it made a significant difference in the slop of my clutch fork. Mine had worn through and allowed the pivot ball to wear into aluminum of the bellhousing. I put a small amount of liquid steel in the hole to take up for the wear and back up the new cup and tapped it in. Problem solved. Don't get carried away with the liquid steel. You only need enough to fill in for the wear. Too much could cause more problems. Thanks! I told him to order the cup bushing and new cone screws while he is at it. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:40 PM |
