Too much travel clutch fork |
Kansas 914 |
Oct 19 2014, 01:45 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I have a friend that is trying to install a new (used) transaxle in his car. He is telling me that he has A LOT of free travel in the clutch fork before he feel any resistance from the T/O bearing touching the fingers on the pressure plate.
He has 3 washers behind the clutch fork pivot ball right now. What can cause significant travel of the clutch fork before resistance? The clutch has all new parts (pressure plate, disk and throw-out bearing). The only part that is not new is the cup washer in the clutch fork. He said there is only about 1/2" space between the fork and the clutch fork opening before it hits the case when trying to engage the clutch. Thanks in advance! |
Mikey914 |
Oct 23 2014, 10:45 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The washers change the geometry significantly. What I was trying to say on the last post is have you tried it with maybe one washer, and was it better or worse. I suspect you only need one or two at most. It sounds "over shimmed" to me.
Kansas 914 |
Oct 24 2014, 08:37 AM
The washers change the geometry significantly. What I was trying to say on the last post is have you tried it with maybe one washer, and was it better or worse. I suspect you only need one or two at most. It sounds "over shimmed" to me. I didn't know the T/O bearing could go on wrong but he is going to check it this afternoon when he removes ALL the washers and installs the new clutch fork cup washer. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:48 PM |
