Too much travel clutch fork |
Dr Evil |
Oct 23 2014, 08:00 PM
Is the TOB installed backwards?
Changing anything from side to tail is useless. The only things that matter in this whole equation: Bell housing to engine dimensions - there should be no difference in the bell housings. Forks - you said they are flat Fork bushing - you said new bushing Pivot ball - if there is a difference in this piece between the two boxes then swap the one that worked. Washers - no more than 2 standard thickness, and that is if flywheel was resurfaced. I seriously wonder if the TOB was installed backwards. |
Mikey914 |
Oct 23 2014, 10:45 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The washers change the geometry significantly. What I was trying to say on the last post is have you tried it with maybe one washer, and was it better or worse. I suspect you only need one or two at most. It sounds "over shimmed" to me.
Kansas 914 |
Oct 24 2014, 08:37 AM
The washers change the geometry significantly. What I was trying to say on the last post is have you tried it with maybe one washer, and was it better or worse. I suspect you only need one or two at most. It sounds "over shimmed" to me. I didn't know the T/O bearing could go on wrong but he is going to check it this afternoon when he removes ALL the washers and installs the new clutch fork cup washer. |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:07 AM |
