Electric Heater, Considering installing a DC Thermal Ducted Heater |
sgetsiv |
Oct 20 2014, 10:05 AM
Former 914 Owner :( Group: Members Posts: 159 Joined: 20-June 08 From: Portland, OR Member No.: 9,192 Region Association: Pacific Northwest |
I have headers (of course) and was thinking I could install one of these directly into the factory ducting:
http://www.my12voltstore.com/12_Volt_Ducte...p/sd12-4000.htm I still have my booster fan, nice flappers, J tubes and plenty of ducting... they make a 50 amp model as well. It would need to be located in the engine bay in my opinion... |
Mark Henry |
Oct 21 2014, 06:33 AM
A 40amp draw is huge and 8000 BTU is not much when heating a cold car.
We're talking clothes dryer draw (in amps) and the average dryer puts out 22,000+BTU |
ClayPerrine |
Oct 21 2014, 06:58 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
A 40amp draw is huge and 8000 BTU is not much when heating a cold car. We're talking clothes dryer draw (in amps) and the average dryer puts out 22,000+BTU Yea, but the clothes dryer is running a 240V. The car is only running 12V. There is a big difference in the available power between 240V and 12V. A 12V car battery will only get a dryer's heater elements slightly warm. Here is the math for it: A 12V heater at 40amps is generating 480 watts. 480 Watts converts to 1638 BTU. The dryer you list above, at 22,000 BTU is pulling 6447 Watts. That works out to 27 amps at 240 Volts. ===================== The ignition system on a 914 will only draw a few amps. It is when you start running lights and wipers to deal with the rain/snow/night that you will exceed the output of the alternator. |
stugray |
Oct 21 2014, 08:33 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Here is the math for it: A 12V heater at 40amps is generating 480 watts. 480 Watts converts to 1638 BTU. The dryer you list above, at 22,000 BTU is pulling 6447 Watts. That works out to 27 amps at 240 Volts. I saw the numbers posted above and was dubious. "That works out to 27 amps at 240 Volts." I dont think that my wife goes out to the garage to plug her hair dryer into my welding outlet (or the clothes dryer). In the US, the most a hair dryer can pull is 15 Amps @ 110V for 1650Watts. Most of them are 1200 watts. Even most electric floor heaters will not pull more than that. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:17 PM |
