Electric Heater, Considering installing a DC Thermal Ducted Heater |
VegasRacer |
Oct 22 2014, 09:20 PM
ELVIRA Group: Benefactors Posts: 8,475 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
The P.O. installed an electric heater in Elvira. If I turn it on at night, the headlights dim by almost half.
It does put out a reasonable amount of heat, but the real problem is air flow. The only time it adds any noticeable warmth to the cabin is if the top is off and both windows are rolled up. |
mgp4591 |
Oct 22 2014, 10:22 PM
914 Guru Group: Members Posts: 5,363 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
If it was efficient enough I'd save weight with one of these rather than a heater coil and the associated plumbing, box and the like. You're right tho- I think I'll stick with using the logical method with my Subie engine... (IMG:style_emoticons/default/idea.gif)
Lo-Fi Version | Time is now: 19th April 2024 - 01:27 AM |
