95mm pistons anyone?, JE forged part number |
Seabird |
Oct 20 2014, 01:48 PM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
Looks like I am in the engine rebuilding way at the moment. Finally got feed up with trying to figure out what was wrong with my engine/auxiliary systems so I pulled the motor this weekend.
Probably the last time out on track the motor dropped a valve guide. Found one broken secondary spring. And I still haven't pulled the driver side head! Fun fun. Ideally I would like to find quality 95mm pistons (allowed a 1.2mm over bore for the class I am preparing to run) and machine my cylinders to match. There does not seem to be a quality 95mm option on the shelf. (I know AA makes a 95mm piston & cylinder set; I am just not interested in buying it.) My question is: has anyone ordered custom 95mm JE pistons and are willing to share the part number? Alternatively is there a source for forged 94mm flat top pistons? All the forged pistons I can find are 96mm or bigger. Thanks, Miguel |
Bob L. |
Oct 20 2014, 01:59 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Never heard of 95mm. 96mm is easily available and will give you a 1911 or 2056cc displacement depending on your crank.
Randal |
Oct 20 2014, 04:29 PM
Never heard of 95mm. 96mm is easily available and will give you a 1911 or 2056cc displacement depending on your crank. 98's with the right crank: 2,414 (IMG:style_emoticons/default/smile.gif) I still have a box with a spare piston. FYI mine has nickies. |
brant |
Oct 21 2014, 04:57 AM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Good for you for trying to go the legal route.
As the local vintage eligibility person for all porsche cars I highly respect your decision. Call EBS. I think they are likely available. The 2056 is technically cheating |
Seabird |
Oct 21 2014, 05:56 AM
Good for you for trying to go the legal route. As the local vintage eligibility person for all porsche cars I highly respect your decision. Call EBS. I think they are likely available. The 2056 is technically cheating Thanks Brant, I'll call over there today when they open. M |
Seabird |
Oct 21 2014, 01:54 PM
Brant,
That worked out perfect. Don at EBS quoted me both ways and helped identify the cylinders I have, original 2.0L Mahles. Boring out my cylinders to 95mm and getting matched pistons was only a couple dollars more so I am going that route. Thanks, Miguel |
Mark Henry |
Oct 21 2014, 02:27 PM
You also could have gone 94 and had the crank done a hair longer stroke
ChrisFoley |
Oct 21 2014, 04:35 PM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
brant |
Oct 21 2014, 05:21 PM
bam914 |
Oct 23 2014, 10:14 AM
Member Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
Order them from Charles @ LN Engineering. That is where I got my 95mm pistons for my EP engine.
Han Solo |
Feb 4 2015, 10:39 AM
Member Group: Members Posts: 288 Joined: 30-September 13 From: Middle Tennessee Member No.: 16,456 Region Association: South East States |
You also could have gone 94 and had the crank done a hair longer stroke No, the rules allow 1.2mm overbore, but no change in stroke. I agree with chris If this discussion is SCCA Solo... here's an interesting change for 2015 in DP. Per Appendix A for DP... Engines with 2-valves per cylinder: 1.00 x listed displacement (cc) Engines with 2-valves per cylinder are permitted a displacement change of +10% via bore/stroke changes only and with the weight formula accounting for the increased displacement. Which should super cede 17.10 ENGINE - DRIVE TRAIN... H. Block 1. The block may be rebored no more than 0.0472” (1.2 mm) over standard unless otherwise specified in Appendix A. So if my math is correct... if you replace OEM 94mm jugs with 96mm and keep the same stroke that's 1971cc to 2056cc with a 4.3% increase. Correct? But that prepared car would need to weigh in at 2056 lbs. |
brant |
Feb 4 2015, 11:45 AM
You also could have gone 94 and had the crank done a hair longer stroke No, the rules allow 1.2mm overbore, but no change in stroke. I agree with chris If this discussion is SCCA Solo... here's an interesting change for 2015 in DP. Per Appendix A for DP... Engines with 2-valves per cylinder: 1.00 x listed displacement (cc) Engines with 2-valves per cylinder are permitted a displacement change of +10% via bore/stroke changes only and with the weight formula accounting for the increased displacement. Which should super cede 17.10 ENGINE - DRIVE TRAIN... H. Block 1. The block may be rebored no more than 0.0472” (1.2 mm) over standard unless otherwise specified in Appendix A. So if my math is correct... if you replace OEM 94mm jugs with 96mm and keep the same stroke that's 1971cc to 2056cc with a 4.3% increase. Correct? But that prepared car would need to weigh in at 2056 lbs. vintage racing... usually to older SCCA GCR's |
Han Solo |
Feb 4 2015, 11:56 AM
vintage racing... usually to older SCCA GCR's Copy that. I was surprised and pleased with this change for us. Especially seeing how I've already bought into 96mm (IMG:style_emoticons/default/piratenanner.gif) Heck, with those rules you could do 98mm (with the same stroke) and still be legal (IMG:style_emoticons/default/smile.gif) |
flmont |
Aug 24 2015, 09:59 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
who does this cylinder boring,..and do they need to be treated after the bore,...plus whats a good crank size to go with such a set-up,..??? Thanks Frank
stugray |
Aug 29 2015, 11:32 AM
Slightly still on topic:
Where can you get a NEW FORGED crank with the stock 71mm Stroke? (other than that NOS 2.0L crank I saw recently for $3000) I see lots of new forged cranks (like at scat), but they are all for stroker motors. If you want NEW & Stock stroke, it seems you are stuck with billet. |
HAM Inc |
Aug 29 2015, 01:51 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Slightly still on topic: Where can you get a NEW FORGED crank with the stock 71mm Stroke? (other than that NOS 2.0L crank I saw recently for $3000) I see lots of new forged cranks (like at scat), but they are all for stroker motors. If you want NEW & Stock stroke, it seems you are stuck with billet. The factory cranks are forged, chilled German steel. Not likely to find a better crank material. |
Lo-Fi Version | Time is now: 5th May 2024 - 10:00 AM |
