Brake Light Switch on Master Cylinder |
patssle |
Oct 20 2014, 08:09 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
If the switch on the master cylinder is suppose to warn of a MC failure - would you know anyways by the brakes not working properly? Or does the light trigger before the MC fails - acting like a warning to eminent failure?
Oct 20 2014, 09:50 PM
No, the switch pretty much doesn't tell you anything until the pedal has already sunk to the floor. BTDT, needed new underwear.
--DD |
Oct 20 2014, 09:54 PM
I thought the sole purpose of it was to remind you that after you replace the master and bleed everything that you need to press that button....it's a self serving button.
Lo-Fi Version | Time is now: 14th May 2024 - 09:41 PM |
