Converting to a 914-6, I am not a mechanic... Am I crazy....? |
Beeliner |
Oct 21 2014, 05:54 PM
Member Group: Members Posts: 398 Joined: 2-August 14 From: Fairfield, CT Member No.: 17,725 Region Association: North East States |
I purchased a 1975 914 that is very original, except for the change of color.
This is my fifth one. I bought three new in the seventies, and two recently. The problem is that I will be mostly supplying the money, and not the expertise... My mechanic is factory trained and was drooling over the opportunity. He just finished a Boxster rebuild over the weekend. Here is a picture of the car. It recently had a rustectomy and new paint. The engine and car is now stock all the way, original FI is still there. It is a DD. I know the car will have to be strengthened, sway bars added, and all of that... But is this an insane project when one is not a mechanic? I don't want flared fenders, so no major exterior cosmetics are to be done... Is $9k for motor and parts reasonable? My mechanic wants to rebuild the engine, so one needing work is what we are looking for. Attached thumbnail(s) Attached image(s) |
carr914 |
Oct 21 2014, 06:20 PM
Racer from Birth Group: Members Posts: 118,049 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
It all depends on how much money you have! To do it right you are talking between $12k-$20k
GeorgeRud |
I doubt that you can do a conversion for $9000 if a six cylinder engine needs rebuilding. There are several threads on conversion parts that are needed and current expected prices.
It is a fun and rewarding project to undertake, but not inexpensive. On my conversion, the engine rebuild alone was over $12,000 when it was finished (though it was done as properly as it can be without shortcuts). Buying a converted -6 that someone else built is the most economical choice, but you miss the fun! |
earossi |
Oct 21 2014, 06:42 PM
Member Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
Converting to a six is not a $9000 project. I know because I am in the middle of doing one. I sourced a 3.2 motor with 75k miles on it......for $7500. If I were to rebuild it, I could easily spend another $10k on the motor alone. Then there are the conversion "accessories". An oil tank for $800, a front engine mount, chassis stiffening to handle the torque, headers will cost you $700 or much more if you insist on heat exchangers.
You would stand some chance of doing such a project.....if your budget is twice what you have stated. As George suggested, the most cost effective way to do such a project is to purchase a project that has already been completed. Sorry to throw water on your desire to do a conversion. |
worn |
Oct 21 2014, 07:08 PM
can't remember Group: Members Posts: 3,144 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I purchased a 1975 914 that is very original, except for the change of color. This is my fifth one.My mechanic wants to rebuild the engine, so one needing work is what we are looking for. I try to spend only about $500 per month. It has been more than two years, but I intend to repaint and reweld as well. I dropped 7 grand on the engine and 911 suspension, You didn't mention the 5 lug conversion that seems a logical partner. That adds cost. If the mechanic "wants" to rebuild an engine, perhaps he will give you a deal on the chance to fulfill that dream. MAybe a discount or ceiling price less parts. Good luck. I can hardly wait to get mine back on the ground with engine. I "want" to weld an oil tank, so there are so many motivations besides money. If you stretch it out you trade something else for the six. |
patssle |
Oct 21 2014, 07:13 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I had zero car experience before I bought my 914. Now I've completed a 914-6 conversion all by myself (well my dad helped too on some aspects). There are countless threads and articles full of advice and previously converted cars on 914world and Pelican that document what you need to do.
It is fun and rewarding to build and pure bliss to drive everyday to work. If you can resolve to the fact that it will cost 10k-20k and are okay with that - then it's a no brainer. Also factor in time - it takes some people months and some years...just depends on your life. Here's my cost thread....ignoring my really cheap motor and carbs: http://www.914world.com/bbs2/index.php?sho...=242910&hl= |
Steve |
Oct 21 2014, 07:15 PM
914 Guru Group: Members Posts: 5,565 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Do your homework.... It's a slippery slope....
Compare the motor with the car it came out of. You should at a minimum, match the brakes to the motor as well as suspension and tires. My first six conversion in a 914 was a 2.7. I also did a 5 lug conversion and went with bigger brakes at the same time. I still had throttle induced over-steer from the motor so i flared the rear fenders for bigger tires. I was very happy with the setup, but the 2.7 was more expensive to overhaul than a 3.2 from a wrecking yard, so i upgraded to a 3.2. For the street I was not happy with the 914/901 gearing with the 3.2, so i replaced the 914 trans with a 915 trans that matched my motor. I will probably upgrade to a 3.6 next, but at least all the other components should be fine. |
Beeliner |
Oct 21 2014, 07:16 PM
It is always better to throw water while the fire is still small....
I was thinking parts budget of $9,000. Labor additional... But parts sound as if they are well north of $9k, correct? |
Mark Henry |
Oct 21 2014, 07:39 PM
$9K in parts can be done but it's a lot of scrounging. It's also a big job so the labour time will be large. Also some parts may seem like a bargain, but are not the best solution. You gets what you pays for.
Then there's the other stuff...brakes, 5 bolt conversion, suspension.... cost creeps up fast. I'm at least $10+K in (don't really want to add up the bills) and I do everything myself, trade parts, etc. and I still have to buy at least $1000 worth of hoses etc My bet getting someone else to turn wrenches you will be damn close to $20K If you're still interested I'd do a lot of research before you jump in. BTW the cheapest and fastest route is to sell your /4 and buy a /6 conversion that has already been done and sorted. |
McMark |
Oct 21 2014, 08:16 PM
Cairo94507 |
Oct 21 2014, 08:41 PM
Michael Group: Members Posts: 9,706 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
That cars looks nice. I would just backdate the bumpers and drive it if the engine is good. Then I would collect parts as you can afford them and once you have most do the conversion.
Chris914n6 |
Oct 21 2014, 09:32 PM
Jackstands are my life. Group: Members Posts: 3,302 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
There are dozens of threads where too much was undertaken all at once and the car has rusted to the jack stands.
I recommend starting with weekend projects: 914 specific wheels and sticky tires. add the sway bars. find and install the 5 lug. Nicer stereo or fresh rubber or other little things that make the car a better DD. Then when there's nothing left and you've met some people test drive a -6. Decide if you need the extra power to enjoy the car. Then decide if you REALLY need it to be a Porsche -6 because other swaps are 2x-5x cheaper to do. |
McMark |
Oct 21 2014, 09:45 PM
Then decide if you REALLY need it to be a Porsche -6 because other swaps are 2x-5x cheaper to do. Cheaper, but far more work. Six conversions are well documented and plenty of ready to run parts out there. I ended up with a 2.4 six while ago. A while later I picked up an oil tank (two actually). More recently I've collected most of the parts for the steering column conversion. Next will be 911 axle components for a 'true' five lug conversion. The point is that I agree with the others. I still drive my car almost every day, but I have a pile of parts ready to go. I won't pull the car off the road until I have everything ready to go. Otherwise it'll end up on jackstands like my other two cars. |
Larmo63 |
Oct 21 2014, 10:10 PM
Get rid of those bumpers first. Then do a five lug conversion. THEN think about the six conversion….IMHO |
EdwardBlume |
Oct 21 2014, 10:14 PM
Sell yours and buy one that is done. At least while you still can.
thelogo |
Oct 21 2014, 10:26 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Yeh no disrespect to all you /6 guys who built these streetlegal
Pure race type cars But the logical standpoint for a person without the " 914 sickness Is to buy a already running and driveing , 6 2.7 crackle high revver Or larger displacement . I would think So it spares you all the labor cost Car on jack stand time And you just add gas and turn the key This is how I got my 1.7 car Only thing not functional was the horn. I'm betting it would be better and faster and I know way cheaper to sell the car and buy a driving 6 . Only con is you don't know the quality or workman ship that went into it. But inspect thoroughly. |
SLITS |
Oct 22 2014, 09:12 AM
WOW!!
$1000 for wiring a /6 into a /4 harness ... the hourly rate must be in the $500+ area. |
Mark Henry |
Oct 22 2014, 09:22 AM
WOW!! $1000 for wiring a /6 into a /4 harness ... the hourly rate must be in the $500+ area. I'm doing a harness and it's way more than a couple hours work if you're doing a nice job...it does say approximate. I'm guessing anything you think is high in Mark's estimate will be used for the unexpected when you're in there. I think he's close to a no surprises estimate with that. If paying for a /6 I would only consider a 3.0 or 3.2, for you I'd go with the 3.2 with stock injection. A smaller /6 can be cheaper but they have their pitfalls, I'd want one with a known history. |
Oct 22 2014, 11:18 AM
First of all, yes you are crazy. But you like 914s, so that was already evident. (IMG:style_emoticons/default/wink.gif)
Next, note that not all of the "conversion stuff" has to be done in every instance. For example, the small-displacement and lower-powered Sixes may not need an oil cooler setup, which takes a lot of $$ out of the parts budget. The five-lug setup is not a requirement, though it is awfully nice to have. A chassis in good shape should not need additional strengthening if the power isn't hugely increased. A local shop can probably make decent headers for not much $$, which drops the heat exchanger cost out of it. And so on. I know of a car that was done for a total parts budget of $7000. It's still a cool driver, but it is not "all that it could be". Some of the improvements could be made later on after the car is driving. Note that this was an exceptional case, though. The engine in particular was acquired quite cheaply (an original Six motor or a 2.0 911T motor for $1500 is a screaming deal!), but the rest of the parts that were used were bought for the then-current going rates. Still, if I were going to do a conversion, I'd be doing a lot of the "extras". And I'd be paying way over $7K for the parts. --DD |
ChrisFoley |
Oct 22 2014, 11:26 AM
I am Tangerine Racing Group: Members Posts: 7,908 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I have a 2.2L under a workbench here that supposedly has S cams, belongs to a customer in NJ.
He's looking to sell it. Needs induction, ignition and exhaust. |
Lo-Fi Version | Time is now: 20th April 2024 - 09:57 AM |
