School me on L-Jet, 2 questions for an L-Jet newby |
ClayPerrine |
Oct 25 2014, 07:27 PM
Life's been good to me so far..... Group: Admin Posts: 15,430 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Here is the simple answer:
If your L-Jet throttle body has two vacuum fittings, hook them both up to the distributor as the diagram shows. If your L-Jet throttle body has only one vacuum fitting, hook it up to the retard port. |
'73-914kid |
Oct 25 2014, 07:59 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Thank you.. the throttle body has a plugged port on it. Hooked it up, and the idle dropped to about 750 RPM at idle, and now doesn't stick on it's way down once it's hot either.
Cap'n Krusty |
Oct 25 2014, 08:28 PM
I guess I failed in my attempt to clarify the port thing. Yes, all 1.8 L-jet 914s use vacuum retard. Some, especially early models, also use vacuum advance. If the TB has no vacuum advance port, then it doesn't use it. If it's there and plugged, unplug the sucker and connect it as it was meant to be. If there's a way to misinterpret what I say, someone will find it. BTW, you not only remove the vacuum line(s) to set the timing, you also plug them for the duration of the process.
The Cap'n |
Porschef |
Oct 26 2014, 10:29 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
My throttle body has no provision for an advance hose to the dizzy.
I'm wondering if'n it would behoove me to drill out the body downstream of the plate and run the line (purple in diagram) This may allow for a small retard in static timing ? Still trying to balance mixture and head temps. AFR gauge and manual diddling of the static arm in the AFM says engine wants to be more lean. Head temp says "I wanna be rich" |
nihil44 |
Oct 28 2014, 03:03 AM
Member Group: Members Posts: 157 Joined: 28-January 12 From: Brisbane, Australia Member No.: 14,058 Region Association: None |
So, if you remove the decel valve, where does the vacuum plumbing go?
The decel valve has 3 ports with lines to:- - to fuel pressure regulator -to air distributor (also called plenum chamber?) -to rubber intake boot between air flow meter and throttle body How does one manage each of these lines? Would appreciate an authoritative response. My 1.8 is demonstrating petulant behaviour at present and needs some firm parenting Thanks David |
timothy_nd28 |
Oct 28 2014, 10:02 AM
Buy some of these and have at it
nihil44 |
Oct 28 2014, 02:49 PM
Timothy,
Thanks for your response but I couldn't see what the product was from your photo and what is its purpose. Would appreciate more info, particularly how the lines from the decel valve are dealt with Thanks David |
Tom |
Oct 28 2014, 06:39 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Rubber nipples to cap off vacuum line you don't want to use anymore.
Tom |
nihil44 |
Oct 29 2014, 03:17 AM
Which ones are no longer in the vacuum circuit?
Does fuel pressure regulator require vacuum? etc Would appreciate some clear explanation David |
Oct 29 2014, 11:17 AM
The L-jet fuel pressure is referenced to manifold pressure. So the FPR does need a vacuum line to it from the manifold.
The Decel Valve is an intentional way to let air go from in front of the throttle valve to after it under some circumstances. (In the D-jet world we call it an "intentional vacuum leak", but in L-jet it lets air that has been measured by the Air Flow Meter go in, so it's not really a leak.) If you remove the DV, then you just plug the fittings that used to be hooked to it. What exactly are you asking for a clear explanation of? Everything in the vacuum system? Just a few specific bits? --DD |
nihil44 |
Oct 29 2014, 01:44 PM
Dave,
Thank you for your reply and satisfactory explanation. I will bypass the valve and hope there is a resolution of the misbehaviour David |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:21 AM |
