Radiator Hose Solution for Suby Conversions, Testing the waters for a group buy |
skeates |
Oct 23 2014, 01:36 PM
Member Group: Members Posts: 218 Joined: 28-February 05 From: Sacramento, ca Member No.: 3,684 Region Association: Northern California |
Hi All - I've been looking into different solutions for merging the two coolant outputs on the 6-cylinder suby motors into a single tube. I finally found something that should work pretty well with these guys Jags That Run. The idea is to use a "T" to merge the two 1-1/8" outlets into a single 1-1/4" hose. The fitting would also be tapped for a 1/4" nipple which would be used as a steam line and routed back to a surge/expansion tank. The following pictures show a rough diagram of my expected set-up and then some examples of their "T" fittings. (Note that I didn't bother including any of the return lines in the diagram)
I'm posting this to see if anyone else would be interested in this fitting since right now it's a one-off production. If I just purchase the one it will be ~$80. However; if I can get 10 or more orders the price will come down to about $30/each! So...any interests? (IMG:http://www.914world.com/bbs2/uploads_offsite/www.jagsthatrun.com-3684-1414093000.1.jpg) |
Chris914n6 |
Oct 23 2014, 11:11 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Every modern v6 I've worked on has water leaving the engine like the pic. I doubt it's an issue.
mgp4591 |
Oct 24 2014, 12:12 AM
914 Guru Group: Members Posts: 5,374 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
skeates |
Oct 24 2014, 09:26 AM
Every modern v6 I've worked on has water leaving the engine like the pic. I doubt it's an issue. Not sure, but maybe because it's a V6 instead of a flat 6? When it all gets sorted, I'd be up for one... And is it for all 6s or just certain models? Awesome! This would be for all of the EZ series Subaru flat 6 motors (EZ30 & EZ36). This would not be needed for the EG33 (SVX motors) since they have a single output for the coolant exiting the motor. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:33 PM |
