1.8 L-Jet to 2.0 L-Jet. Any advice? |
mapguy |
Oct 24 2014, 10:09 PM
Freelance Generalist Group: Members Posts: 90 Joined: 31-January 14 From: Inland Empire, CA Member No.: 16,945 Region Association: Southern California |
Howdy,
I have just torn down a bone stock '74 1.8 L-Jet from another 914 with plans to build it back to stock. Plan is to drive my 914 with this engine while I build the original 2.0 the way I want it. I get experience building my first type 4, and get my teener back where it belongs. On the road. I have the parts available to swap out the crank, rods, and P/C from a '76 2.0 to make it a 2.0 L-Jet. I'm very tempted to do this, as I rarely turn down cheap horsepower! No replacement for displacement, right? Any land mines I should look out for? Main concern for me is the stock L-Jet system. I understand I might have to tune the MAF for the extra displacement, but I can't find anything discouraging me otherwise. I found an article that details a 3-step process for MAF tuning, but am too lazy to look up the link. Do tell if you know something I don't. More details: As implied, stock '74 L-Jet system Stock '74 1.8 heads (41x34, I believe) web cam 142/lifters necessary machine work Cylinders honed and new rings (I have a set of 94s in excellent condition) Full re-seal on engine and all peripherals New fuel lines, vacuum lines, etc etc... One other thing, I haven't built many engines, but all the ones I've been involved in pop through the intake when first firing them off, and one in particular did it several times before finally lighting off (my old bus engine was a PITA to get running first time). Won't this be dangerous for the MAF on first start? All my experience is with carbed engines. Does this just not happen on FI engines? Any advice is greatly appreciated. |
MrKona |
Nov 2 2014, 09:37 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
I ended up lengthening the recess to fit the Vanagon plate on the stock 1.8 L-jet throttle body shaft.
I created a separate progress thread here. |
Lo-Fi Version | Time is now: 13th May 2024 - 02:09 AM |
