GB - Improved tail cone speedo drive with additional seal, Thanks to McMark for this one, stop a leak! $42.99 - $65 after GB |
Mikey914 |
Oct 25 2014, 03:15 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This is a service that McMark had been doing for some time. It adds an additional sealing surface to the speedo drive bushing by cutting a channel in the OEM part. It required you to send in yours and he had to have a few to make it worth while, so it took a little time to get these together.
After speaking with him regarding this, we came to an arrangement, that would allow for new ones to be on the shelf for those that need them at the shop, or just want a local pick up. So you can buy from him or I will also stock on my site. Either way, it's better than the exchange program. And by the way the OEM non modified part is over $150. For those of you that are not quite sure what the significance of this is, it adds the extra seal to eliminate the nagging drip off the speedo angle drive. It comes with the 2 o-ring seals and the internal drive seal. These will be up on the site shortly to allow to combine with any other GB's Bump if you want to be notified when up. Also one of those while you're down there with the clutch cable jobs. Attached image(s) |
Mikey914 |
Oct 25 2014, 03:19 PM
The process is pretty straight forward. However you will need to change your trans fluid, or at least strain if you have done so recently. As this is in a low point submerged in the trans fluid.
Once the old one is removed allow 30 min for it to drain. Take the old geared shaft from the removed unit, as well as the washer and set aside. Put the shaft into the new bushing, and set it as the base. Attached image(s) |
Mikey914 |
Oct 25 2014, 03:20 PM
Take the seal shown (the bottom side is shown) and set onto the shaft.
Mikey914 |
Oct 25 2014, 03:22 PM
Lubricate, I used WD40 as it's not real messy. Then using a socket (I used 13mm, but a 12 is a little closer) Gently tap the seal into place. It is a tight fit, but once seated is very difficult to remove.
Mikey914 |
Oct 25 2014, 03:24 PM
Don't forget to replace reinstall the aluminum washer. These are $9 from Porsche so don't loose it.
Mikey914 |
Oct 25 2014, 03:26 PM
Once you have the gear and seal in you can install so that the hole in the unit lines up with the bolt hole in the tail cone assembly.
I did use WD40 to install as it is a tight fit. Attached thumbnail(s) Attached image(s) |
Mikey914 |
Oct 25 2014, 03:28 PM
PLEASE NOTE -
You do not have to take off the tail cone assembly to do this. I happened to have an extra part so it was easy to show this. However if you do wish to I have the tail cone gaskets only for $5 on the site. I have one last GB to list, and then I will be adding to the site, so bump if you are a +1, I'll notify everyone on the thread. Thanks all! |
Cap'n Krusty |
I can tell you that this WORKS! I've bought several of them from McMark and used them to fix transaxles that have suffered from years, if not decades, of speedo drive leaks. This should be part of every 914 trans overhaul, or even "freshening up".
The Cap'n |
pilothyer |
Oct 25 2014, 03:37 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Remind me for 2 of these.
walterolin |
Oct 25 2014, 03:49 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
One.
McMark |
Oct 25 2014, 06:32 PM
Thanks for taking this over Mark. No more cores to deal with now! (IMG:style_emoticons/default/smile.gif)
GermermanCarGuy |
Oct 25 2014, 07:07 PM
GermanCarGuy Group: Members Posts: 81 Joined: 13-May 14 From: Rapid City, SD Member No.: 17,346 Region Association: Upper MidWest |
One please.
restore2seater |
Oct 25 2014, 09:54 PM
Future 914 copilot. Group: Members Posts: 311 Joined: 30-October 04 From: Dunlap,IL Member No.: 3,037 Region Association: None |
Put me down for one.
carr914 |
Oct 26 2014, 02:18 AM
Racer from Birth Group: Members Posts: 118,160 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I want 3 Please!
Java2570 |
Oct 26 2014, 06:55 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Put me down for one, please!
Dtjaden |
Oct 26 2014, 09:26 AM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
I'll go for one!
kid914 |
Oct 26 2014, 09:56 AM
ALWAYS lead...NEVER follow!!!! Group: Members Posts: 2,534 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
So this is for trannies? 901- 915?
(IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/blink.gif) |
Mikey914 |
Oct 26 2014, 11:09 AM
911- 1965-1973
914 all It's equivalent to part # 901.318.243.12 I believe it's a 901 only |
wes |
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
+1 for me
7275914911 |
Oct 26 2014, 12:13 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
I need 1 of these plus in on Badge buy also....
Lo-Fi Version | Time is now: 25th April 2024 - 01:04 PM |
