Valve adjustment problem w/hydraulic lifters |
rjames |
Oct 25 2014, 05:09 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Verifying valves are set properly and I can't adjust one of the exhaust valves past zero lash without tremendous effort. The associated pushrod doesn't budge. None of the others are that way. Do I need to pull the lifter or is there a chance I can run it at zero lash for a few minutes and try adjusting it again without hurting anything?
Cap'n Krusty |
Oct 25 2014, 06:48 PM
There is a known bleed problem with some of the Febi lifters. I have a bunch of bent valves on my Vanagon to prove it. One style has the wire clip, the other has a snap ring. I forget which design is bad, and I can't get a look at them until first of the week.
The Cap'n. |
Lo-Fi Version | Time is now: 20th May 2024 - 12:07 AM |
