Valve adjustment problem w/hydraulic lifters |
rjames |
Oct 25 2014, 05:09 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Verifying valves are set properly and I can't adjust one of the exhaust valves past zero lash without tremendous effort. The associated pushrod doesn't budge. None of the others are that way. Do I need to pull the lifter or is there a chance I can run it at zero lash for a few minutes and try adjusting it again without hurting anything?
rjames |
Oct 25 2014, 07:35 PM
So don't run the engine, and remove the lifter. (IMG:style_emoticons/default/mad.gif)
I probably should have mentioned that I think the cause of this was mis adjusting the valve to begin with. I looked all over for a thread showing how to remove the lifter but couldn't find one. Do I just undo the visible nut on the rocker assembly? Can I do this with the engine in the car? Do I have to do this? I'm supposed to have the car moved for a new garage door install on Monday. (IMG:style_emoticons/default/mad.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 09:53 PM |
