Valve adjustment problem w/hydraulic lifters |
rjames |
Oct 25 2014, 05:09 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Verifying valves are set properly and I can't adjust one of the exhaust valves past zero lash without tremendous effort. The associated pushrod doesn't budge. None of the others are that way. Do I need to pull the lifter or is there a chance I can run it at zero lash for a few minutes and try adjusting it again without hurting anything?
rjames |
Oct 26 2014, 05:24 PM
Put it at TDC for #3 as instructed. (Exhaust #3 is the problem lifter) Got the pushrod out, now what? What's a suitable tool to remove the lifter? I don't think I have anything as long as the pushrod in my tool arsenal. (IMG:style_emoticons/default/unsure.gif)
Do I have to remove the wire retaining spring thing to remove the lifter? (Which will require me to take off the adjacent rocker) |
Lo-Fi Version | Time is now: 19th May 2024 - 10:41 PM |
