Valve adjustment problem w/hydraulic lifters |
rjames |
Oct 25 2014, 05:09 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Verifying valves are set properly and I can't adjust one of the exhaust valves past zero lash without tremendous effort. The associated pushrod doesn't budge. None of the others are that way. Do I need to pull the lifter or is there a chance I can run it at zero lash for a few minutes and try adjusting it again without hurting anything?
messix |
Oct 26 2014, 05:46 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
remove rockers, remover push rod tube, you should be able to pull it out to were you can tilt it down and pull it pull it out. then reach into to lifter bore with reverse snapring tool and pull out.
I did this with the engine in car but exhaust removed. |
Lo-Fi Version | Time is now: 19th May 2024 - 11:33 PM |
