Valve adjustment problem w/hydraulic lifters |
rjames |
Oct 25 2014, 05:09 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Verifying valves are set properly and I can't adjust one of the exhaust valves past zero lash without tremendous effort. The associated pushrod doesn't budge. None of the others are that way. Do I need to pull the lifter or is there a chance I can run it at zero lash for a few minutes and try adjusting it again without hurting anything?
Nate |
Oct 27 2014, 02:16 PM
Newbie Group: Members Posts: 47 Joined: 21-August 14 From: Southern California Member No.: 17,807 Region Association: Southern California |
No. You actually don't need to remove the rocker arms at all to remove the push rod tube retaining spring. By the same token, you can put all the rocker arm assemblies in, then do your valve adjustment, then lastly put the push rod tube retaining spring back in so it's not in your way during the process. you do want to make sure the retaining spring is not binding or contacting the rocker arms or push rods at all once you put it back in.
Lo-Fi Version | Time is now: 19th May 2024 - 11:56 PM |
