left side outer clam shell for the long For early 4 and factory 6's |
rick 918-S |
Oct 26 2014, 06:20 PM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I just cut this part off a 71 parts car I have. This is a nice left side outer rocker. I am going to split the inner and outer panel. so I'm only selling the outer panel. It's a lot of work to split these panels so this isn't going to be a cheap part.
I am only selling this panel to a guy that needs a panel for a factory 6 or high end restoration. The early stamping is not being reproduced and the triangles available are for the right side and face the wrong way when installed on the left. This is going to cost $ 250.00. plus shipping. I'll post more photos when I get the panels separated. The part will include the rear rail section you see that is attached as well the triangles and jack post. If I were going to use this I would send it out to be E-Coated. Attached image(s) |
rick 918-S |
Oct 30 2014, 06:51 AM
If you have left side rust you need this part for a correct look. Restoration design makes the late style part. It fits fine but does not have the correct stampings they don't make the left side rail section. (IMG:style_emoticons/default/icon_bump.gif)
rick 918-S |
Dec 5 2014, 09:48 PM
If you have left side rust you need this part for a correct look. Restoration design makes the late style part. It fits fine but does not have the correct stampings they don't make the left side rail section. (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/icon_bump.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 09:43 PM |
