D-Jet questions, Air flow meter and head temp |
OU8AVW |
Oct 28 2014, 07:19 AM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
I am hooking up all the D-Jet components and i have a few questions. My motor is a 2.0 out of a 1975 car built to a 2056 with a Raby FI cam. I'm using all stock FI.
I might have forgotten something. I have my head temp sender but I'm not sure how it connects. Tin is installed so I see that is goes into the hole next to the #3 intake but does it screw into the head somewhere? Do i have to pull the tin off to install it? (IMG:style_emoticons/default/dry.gif) Next: I see on my harness a plug for the air flow meter but my car came with a stupid aftermarket air cleaner. Where shiuld the AFM be? Is it attached to the stock air cleaner like my bus and 944 or is it a separate thing attached next to the battery tray? One more: My heads have two breather holes each adjacent to the intakes. I am told I should block these off. Anyone know what thread they are? When I got the car they were blocked with bronze pipe fittings. Should I make one of these a proper breather? Thanks! |
OU8AVW |
Nov 1 2014, 10:43 AM
So, heads are bass akwards. What's the penalty for leaving them and pulling head temp off of #1? Any other issues?
Lo-Fi Version | Time is now: 17th May 2024 - 06:29 AM |
