6/ oil reservoir, what size fitting? |
altitude411 |
Oct 29 2014, 04:26 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
What size fitting is on the oil line that connects to this? Is it 33mm? 36mm? TIA
Luke M |
Oct 29 2014, 06:11 PM
Senior Member Group: Members Posts: 1,368 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Do you need to know the wrench size to fit the fitting or what size the fitting id is?
I'll go find my 6 oil return hose and measure it for you. |
altitude411 |
Oct 29 2014, 06:23 PM
sorry for the confusion... I need the wrench size please. I'm 45 miles to a decent parts store and would like to pick up a wrench before heading home. Thanks for your time.
GeorgeRud |
Oct 29 2014, 07:23 PM
If you're using original hoses and fittings, 32 and 36 mm open ended wrenches are needed to service the oil lines.
altitude411 |
Oct 29 2014, 07:27 PM
Thanks for that George, much appreciated.
Cfletch |
Oct 29 2014, 08:20 PM
Member Group: Members Posts: 104 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California |
want to buy lol i need of for my conversion (IMG:style_emoticons/default/sad.gif)
wndsnd |
Oct 29 2014, 08:39 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
What tank is that. Did you test fit it yet? Think it will be an easy install?
John |
Cap'n Krusty |
Oct 29 2014, 08:52 PM
Looks to me as if it's a factory sportomatic tank.
The Cap'n |
altitude411 |
Oct 29 2014, 09:44 PM
It's just a pic I pulled off the net for a reference. Mine is still in the car.
*I believe it (pic) is a sportomatic tank as per the extra orifices... |
gereed75 |
Oct 29 2014, 10:18 PM
Senior Member Group: Members Posts: 1,239 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
It's just a pic I pulled off the net for a reference. Mine is still in the car. *I believe it (pic) is a sportomatic tank as per the extra orifices... I picked up a set of open end wrenches at Harbor freight. http://www.harborfreight.com/15-piece-metr...-set-93668.html They are called "service wrenches". The set has like 21 - 36mm. The quality was adequate to get my oil lines off. set was $49.00 not on sale. They are relatively thin and fit into places they need to to break the lines. You can also easily get a pipe on the ends for LEVERAGE!! (IMG:style_emoticons/default/evilgrin.gif) |
wndsnd |
Oct 30 2014, 07:46 PM
Looks expensive.
John |
Lo-Fi Version | Time is now: 18th April 2024 - 09:09 PM |
